Missing a/c return air grill
b_pilot
I have a Lifestyle 5th wheel made by Evergreen RVs. The two a/c units are mounted on top of the camper and have ducts that run down both sides of the camper to distribute the air. There is a return air vent in each of the ducts. One of the grills that holds the air filter in place fell out with the vibration of traveling. It must have fallen on top of the slide out and then was pushed outside when the slide was put out. Anyway, it is gone, and I need a replacement. Can't go to Evergreen as they went out of business several years ago. I have checked the internet and some of the local parts dealers around here. Does anyone have an idea of where I should look? The air return vent is 6x12 inches. I have to find something so the filter will stay in place.
26 REPLIES 26
b_pilot
Cummins12V98 wrote:
This is what I have in my DRV. Two per AC.
That is the same setup in my Lifestyle but my grill is different. Does your grill have a filter behind it or is the filter in the a/c?
Cummins12V98
agesilaus wrote:
BarneyS wrote:
Interesting! I learn something new almost everyday here. Thanks.:)
Barney
You can find a wide assortment of that sort of vent cover at Loews or Home Depot.
Very common product used in Residential and Commercial Construction.
Buy based on actual hole size.
OP I glued small pcs of 1X material on top side of roof panel above screw hole with LocTite PL3 Construction Adhesive then pre drilled holes thru block after adhesive had set. I used a drill bit the size of the shank of the screw so block above would not split when running the screws in.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
agesilaus
Barney
Arctic Fox 25Y Travel Trailer
Straightline dual cam hitch
Superbumper
BarneyS
Barney
Not towing now.
Cummins12V98
Mine is a 6x10 opening with 8x12 overall dimension.
BarneyS
b_pilot wrote:
My a/c is an AIRXCEL which is coleman. The air return is not a part of the a/c unit. It is a ducted system with the return air vents separate from the a/c itself.
You need to post a picture of the thing you want. My trailer has a ducted system also and had a ceiling cover/filter exactly as the one I pictured above. My new air conditioner, an Atwood, has one similar and my sons trailers both have Colman with similar ceiling covers/filter. I have never come across an RV with a roof air conditioner that did not have a similar ceiling unit. :?
Edit:
Here is a ceiling unit of a ducted Colman Airxcel air conditioner. Does yours like look like this or similar?
Not towing now.
wildtoad
Can you post a pic of the other one?
Tom Wilds
Blythewood, SC
2015 Jeep Wrangler 2dr HT
Cummins12V98
Itโ€™s not RV specific if itโ€™s like mine.
b_pilot
Cummins12V98
Amazon simple return air grill.
agesilaus
I'd check a local RV parts store, those a/c units are standardized. I needed the inside filter hold and went to the local shop they had a whole big box full of them, apparently a common replacement part.
Superbumper
BarneyS
What make air conditioner do you have? As far as I have seen, all trailers and motorhomes with air conditioners have the return air as part of the conditioner itself (actually, it is part of the ceiling cover but contains the filter). It should be available at just about any RV place or on the internet.
Barney
Does yours look like this?
Not towing now.
