We are living in a Montana High Country 310RE. We've been having problems with the dinette slide leaking, pretty bad actually. Some how the rain is causing water to come up through the floor and soaking the carpet. We know we need to get it back to the dealer, it's finding the right time and of course other living arrangements. Wondering if someone else has had the same issue's. Thanks
Get yourself a ladder and check the slideout roofing where it meets the outside wall of the slideout. This area is often the source of leaks. It may need to be recaulked.
9-11 WE WILL NEVER FORGET! FULLTIME SINCE 2010 17 DRV MS 36rssb3 17 F350 King Ranch CC DRW 4x4 6.7 4:10 B&W hitch John โA good traveler has no fixed plans, and is not intent on arriving.โ Lao Tzu
You might also check the slide-out seals and verify that they "popped" out toward the outside edge of the room. That made a difference on our last trailer.
Mark and Dianna along with Hank the Wonderdog 2015 Ram 3500 DRW 2016 CC Silverback 33IK
We had a similar problem in our Chaparral. Found out is was coming in from 2 places. Some from a window not being sealed properly. The main was was the flashing on the facia. They never caulked it. The water was running down the inside of the wall and wicking through the carpet. Once it was caulked and Window sealed all stopped.
Good luck.
Dan & Patty Miss Pickles the Pomeranian Princess Rainbow Bridge 8/8/2023 2020 GMC 3500 Sierra Denali 6.6 Duramax / Allison tranny 2021 Jayco Eagle 319MLOK BWRVK 3710 companion Maddy the Pampered Pom @ Rainbow Bridge 12-3-2013
