โAug-13-2016 07:31 PM
โAug-19-2016 01:32 PM
โAug-19-2016 09:34 AM
eDUBz wrote:
Ill have the shop inspect and repack them.
โAug-18-2016 07:22 AM
โAug-18-2016 07:02 AM
nayther wrote:eDUBz wrote:
you should do it. Going to replace all my bearings soon.
Don't be so quick to "replace" bearings. pull them apart, clean and inspect. if the rollers and races are nice and smooth and shiny then repack with good grease and you're good to go. Properly maintained wheel bearings will last a lifetime.
โAug-18-2016 06:41 AM
โAug-17-2016 09:14 AM
nayther wrote:you should do it. Going to replace all my bearings soon.eDUBz wrote:Blackdiamond wrote:eDUBz wrote:nayther wrote:yup. Lost the wheel and drum.
So did you lose a wheel bearing? I assume that's what caused the failure.
So, what really happened, the axle nut came off, right??
Did the bad bearing cause play/stress on the cotter pin and nut causing the cotter pin to fail and then the nut backed off? Did the axle get ruined? If it didn't, why not?
No, the axle nut and cotter pin were still there. The bearing failed and everything just came off. I got super lucky no other damage was done.
common problem on boat trailers back in the day. Makes me want to check/pack my wheel bearings, been a bit too long.
โAug-17-2016 08:26 AM
โAug-16-2016 05:49 PM
eDUBz wrote:24fb freedom wrote:
Just saw you in littlerock, I imagine your heading home, glad everything worked out well
That's was cool, my wife was like WTF hahaha. We pulled up so she can get lunch out of the trailer. We are home now.
โAug-16-2016 02:38 PM
โAug-16-2016 11:52 AM
โAug-15-2016 03:30 PM
2014 RAM 3500 Diesel 4x4 Dually long bed. B&W RVK3600 hitch โข 2015 Crossroads Elevation Homestead Toy Hauler ("The Taj Mahauler") โข <\br >Toys:
โAug-15-2016 02:25 PM
โAug-15-2016 01:02 PM
โAug-15-2016 12:38 PM
