Nov-25-2018 09:21 PM
Nov-27-2018 08:13 AM
MFL wrote:
GM owes you a set of tires, if the OEMs were below RAWR. 🙂 I'm not familiar with 245 Es from 02, but most of the ones I see are rated 3195, which covers the 6,000 plus/minus RAWR of many 2500s.
Likely too late to collect on those tires, as GM is scaling back/cost cutting as we type.
Jerry
Nov-27-2018 06:24 AM
Kory426 wrote:
Hey y’all. Picked up a 5th wheel through my grandparents last week. It’s designated for the 1/2 ton trucks. But I have a 1500 Silverado crew cab with the 5.5 or so bed. I’ve been looking at new slider hitches but have recently came upon the concept of sidewinder combo where the turret spins. Anyone have any experience with this? Looking for pros/cons on the Automatic slider- Manual slider - kingpin concept. Thanks guys!
Nov-26-2018 03:10 PM
Nov-26-2018 12:28 PM
Nov-26-2018 12:25 PM
Nov-26-2018 12:10 PM
MFL wrote:laknox wrote:
I don't know of any GM truck beds that are 5.5' in the Silverado line. 6.5' is the usual short bed length. Depending on the FW, you may, or may not, need a slider.
As MFL said, you need to know the rear axle weight rating (RAWR), but he forgot to mention tires. Likely you only have D rated tires. E rated tires can be used and that will give you a lot more tire capacity.
Lyle
Yes Lyle, they do make a Silverado 1500 extra short bed that is 5'8"s. You are correct on upgrading the tires , however OEM tires are covered by the RAWR, normally just above the rating a couple hundred lbs or so. Typically if staying within RAWR, you are also under tire rating.
Jerry
Nov-26-2018 12:07 PM
Lyle
Nov-26-2018 11:55 AM
Allworth wrote:
GM does not list a 5.5' bed as original equipment. New or used as far as I can research.
Nov-26-2018 10:24 AM
Nov-26-2018 09:46 AM
Nov-26-2018 06:44 AM
Nov-26-2018 03:25 AM
Nov-26-2018 03:23 AM
