noheat/ no air
canucksam
I have a prowler 5th wheel,woke up this mornig to a non-workingheat/air system
checked fuses changed thermostat -still non-functioning Any suggestions??
5 REPLIES 5
pyoung47
If you have a Dometic AC, changing the thermostat involves a specific thermostat -- not a Lowes model. In my unit, it controls a relay box located in the AC which also controls the furnace.
If the new thermo did not solve the issue, I would put the old one back to be sure I wasn't adding another issue.
1Wheeldrive
We would need more information to try to help. Are you hooked up to shore power, or running on batteries? Did the fan operate, but no heat, or was there no fan and no heat? Do you have propane? Need that information in order to start a diagnosis.
2015 GMC Sierra SLT 3500 CC Long Bed
2012 Voltage 3200
2006 KLR 650
TXiceman
You need to tell us a bit about the trailer, A/C and heat make and model and if you have an energy management system.
Ken
Amateur Radio Operator.
2023 Cougar 22MLS, toted with a 2022, F150, 3.5L EcoBoost, Crewcab, Max Tow, FORMER Full Time RVer. Travel with a standard schnauzer and a Timneh African Gray parrot
the_bear_II
Not enough shoreline voltage
No 12 volts or batteries are too low
enblethen
Make and model of furnace?
Some have a circuit breaker adjacent to the fan motor. Most have small white or red reset.
You did test the fuse?
Check for incoming power to furnace.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
