Open Range Slide @ Myrtle Beach
3_dog_nights
I want to get my slide cables checked and adjusted while I'm at MB. Does anyone know of a experienced tech on the north end??
Bob & Lynn
2 Chihuahua's, Ella, Gracie
was-2013 Open Range 424RLS,06' Chevy 3500, dually, Duramax/Allison
also was - 2015 Winnebago Adventurer 37F, towing 2003 Jeep Wrangler
now - 2021 NoBo 19.5, 2019 Honda Ridgeline RTL (Talk about downsizing!)
6 REPLIES 6
Dandy_Dan
3 dog nights wrote:
FYI - Just got home. I talked to three different companies that were working in the campground. None of them had worked on the OR cable systems before. One said he'd give it a shot but I passed. Don't want to be his "lesson"
Go to the web and go to BAL Inovative Products. That is the cable system OR uses. It gives you a lesson on the cable system. Good Luck and Happy Camping in your OR.
dan218b@tds.net
Dan and Lori Branson
Anna 1 and Lily( The new one)
Sarah-7/16 and Beau at the Rainbow bridge
2015 Ford SD350 Crew Cab Power Stroke
2009 Open Range 337RLS
Old Fella Rally Member
RV.Net Ohio Rally Member
avvidclif1
Smart move.....
Clif & Millie
2009 Ford F350 SRW CC Lariat 6.4 Diesel
2015 Heartland Cyclone HD CY3418 Toy Hauler
3_dog_nights
Bob & Lynn
glazier
I remember seeing Costal RV services there.
2017 Grand Design Momentum 328M
2015 Chevy 2500HD LTZ Duramax CC/SB/4X4
B&W Companion Slider
Vulcaneer
Check at the C/G office. They usually know of the good mobile techs. Or good local RV shops.
Here's the way I check mine. If it moves smoothly and easily, and it seals on the inside (when it's out, and on the outside when it's in). And the cables are not rubbing or fraying, it's good.
If it's not good it needs adjustment. I get out my vice grips and 7/6 wrench and adjust til it does as above. Usually about 10 minutes.
I found, I can service these slides as well as most other monkeys. Most of them really do not know what they are doing. Finding expertise on these is a real problem.
'12 F350 SB, CC, SRW, 6.7 PSD, 3.55 RAR, 6 spd auto
2015 DRV 38RSS 'Traditions'
Pullrite Super Glide 18K
Retirement = It's all poops and giggles....UNTIL someone Giggles and Poops.
byrdr1
3 dog night.. sounds like a rock group, :).
Check with Camping Connection/ 843-238-3329. They are on the south side but I am sure they work mobile at all the CG's in that area. A good guy runs the company. They have a place at myrtle and Kissimmee, Fl I think it is. I saw them in Ocean Lakes working on campers in May. CW might have mobile service down there too.
randy
2014 F-350 SRW CC/LWB 4X4 6.7PSD
2011 Keystone Cougar 327RES
Happy Campin'
Randy
Piedmont area of NC
