Ordering front landing gear
RAllison
Ordering front landing gear for my 2005 Keystone Sprinter 294FWDB. Dryweight is about 8000#s. I'm not sure what size to order,thought I might get some help here. Thanks, Rich
7 REPLIES 7
fj12ryder
You'll love the Bulldog system, smooth and quiet.
Howard and Peggy
"Don't Panic"
RAllison
Well,I ordered a Bulldog system from etrailer. Hopefully it will bolt in without to much problem. Thanks for the info.
Shrek51
I recently replace my stock jacks after it failed. Try a duel motor jacks from Ultra-Fab(I bought) or BullDog( I recommend because of duel speed). They also give you more room in the front compartment.
If they fail you can order parts individually instead of the whole thing.
Veebyes
Also need to be sure that whatever is bought is compatible with attaching to the frame.
Landing legs complete with motor are not terribly expensive. Might be better to get independent legs with motors.
2007 Alpenlite 34RLR
laknox
RAllison wrote:
The gear it had was Fulton, which no longer makes this type. It has electric and I'm putting the same back in. I only need the jacks, I can reuse the electric motor.
Better make sure the motor will bolt up to whatever legs you get =before= you order. :B
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
RAllison
agesilaus
What does it have now? What type to you plan to add, manual, electric, or hydraulic?
Arctic Fox 25Y Travel Trailer
2018 RAM 2500 6.7L 4WD shortbed
Straightline dual cam hitch
400W Solar with Victron controller
Superbumper
