Picky Choosing
mtnguy
The missus and I are looking for a 5th wheel. We plan to hit the road a couple of months in the spring and again in the fall every year. So far, I haven’t been able to find exactly what we want, so I thought I would put it out to the forum. We would prefer a unit that has:
A regular length queen bed on a slide, with windows and a night stand on each side.
A wardrobe all of the way across the front cap.
2 recliners facing the entertainment center…..not a unit where you gotta crook your head to see the TV.
A fully usable unit with the slides closed (TV viewing would not be necessary). We want to be able to get to the bathroom, access the fridge, and eat at the dinette with the slides in. 1 slide in the living area would be good, and we would prefer that the fridge or stove not be on a slide.
We would like to keep our length down to about 32’ overall.
Don't want much, do we ?? 🙂
Thanks in advance.
18 REPLIES 18
mtnguy
I plan on spending 2 days at the Hershey RV Show in September. Just checking in here to see if someone can get me in the ballpark with a model number that I can check out.......plus, not all models will be at the show.
rugermark2
My suggestion would be to go to an RV show. Bring a note pad, look at the different models and take notes about pros and cons of the one you like.
2011 Ram 2500 6.7 Cummins
2015 Cougar 29RLI
the_bear_II
Some items can be changed by the factory or dealer...
Dining table and chairs instead of dinnette. Recliners instead of sofa or sectional or theater seats.
TV in spot of your choice.
You may be able to have some modifications made by the dealer or if you order from the factory. Or DIY...we added a desk/dining table setup and replaced the RV type recliners with two from LazyBoy. I added an electric fireplace in place of 3 drawers.
But ability to use when slides are in you'll need to find the right floorplan.
Good luck on your search.... you'll find something that will work.
Mfan
Just a suggestion, our 2 recliners on back wall are 90 degrees from tv. Our tv is on a pull out swivel mount. We watch straight on.
