Pin wear (pics working now)
caseybloo
How much wear is too much. I can feel some slack when towing. Just wondering about fixing or replacing.
2009 Coachmen Dreamcatcher 335RET
2010 Ram SLT 3500 dually
14 REPLIES 14
larry_barnhart
I use white grease to grease the pin before each trip and clean it off on arrival.
chevman
chevman
2019 rockwood 34 ft fifth wheel sold
2005 3500 2wd duramax CC dually
prodigy
KSH 55 inbed fuel tank
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
FMCA # F479110
Me_Again
45Ricochet wrote:
So your highly hazardous loads ( gasoline :E ) had a sliding bar hitch also ? That's what I thought :W
I even bet you never lost the trailer because of not being latched correctly :B
Actually the tanker trailer did not have landing gear. So I only dropped it when the tractor had to be serviced without the trailer. I did the washing, oil, grease, filters and brake work myself in our fuel depot. I sweat bullets each time I hitched the Titan 90 tractor back up. We jacked and blocked the trailer up on oil drums.
Trailer was 8500 gals, aluminum and weighed just 10k. I did have a 4 way 5th wheel hitch.
Did like the 13 speed Roadranger. Much better than my fathers 5x3. Chris
45Ricochet
2015 Tiffin Phaeton Cummins ISL, Allison 3000, 45K GCWR
10KW Onan, Magnum Pure Sine Wave Inverter
2015 GMC Canyon Toad
Previous camping rig
06 Ram 3500 CC LB Laramie 4x4 Dually 5.9 Cummins Smarty Jr 48RE Jacobs brake
06 Grand Junction 15500 GVWR 3200 pin
Me_Again
45Ricochet wrote:
Thanks OP for the hitch information. That's what I thought from the get go. Double Jaw system is much easier on pins, right Chris :W
Never have liked the slide bar type hitches since the big boys don't have em.
Well! I got my Hijacker sliding bar hitch in 1997, it is in it's second truck and has towed this second 5th wheel starting in 2004. No wear problems. Never worried about it being correctly latched! I keep it looked to the bed rails, as I do not want to ever loose it.
Chris
kennethwooster
Just bought a B&W Companion and love it. Easy hook and unhook. Instead of grease I'm going to paint with slip plate, and refresh it on a regular basis. That way the dirt is not attracted.
kenneth wooster- retired farmer. Biblical History Teacher in public HS, and substitute teacher.
wife Diana-adult probation officer, now retired.
31KSLS Full Body paint Cameo
Ford F350 2014 DRW 4X4 King Ranch.
20K B&W Puck mount hitch
45Ricochet
caseybloo
Thanx folks for your input. This is such a good classroom to learn in. It is a Pro Series 15000 going into 5th season. Guess I am shopping for new hitch.
wandering1
Why put grease on it? Haven't ever put grease on mine for 15 years and it shows no wear and works fine.
HR
laknox
Me Again wrote:
What kind of hitch is in the truck? Chris
That first pic appears to be the locking bar on a sliding bar-style hitch. Put all that pressure on that small and area, and that's what you get. AFAIK, there are 3 ways to fix this; 1) replace the FW hitch with a wrap-around jaw-style (B&W Companion), and do nothing to the pin, 2) replace the pin box, but you still have the same style hitch, which will cause this again, 3) have someone weld up the groove in the pin and grind it back down. Again, without a hitch change you'll end up in the same place, eventually. It's also not real cost-effective.
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
45Ricochet
Yeah I'd like to know that too. Like someone said grease plus dirt is not a great combo. That is the worst looking pin I've seen.
Me_Again
Bigfoot_affair
Nomad II
Nomad II
Grease and dirt = grinding compound. That thing looks like it hasn't been cleaned in a long time.
greende
Call a place that repairs Big Rig trailers. They have a pin guage that will tell you if it is worn enough to replace. Looks pretty bad to me.
2011 Chevy 3500 HD LTZ Duramax/Allison Crew Cab Long Box DRW
B&W Turnover Ball with Companion
2012 Keystone Cougar 293 SAB 5er
USAF 1968 - 1972 Viet Nam '71 - '72
waltbennett
I'd figure out how to replace it for certain. Bigger issue is what's causing that wear? Looks like you've been putting grease on the pin, but maybe it wasn't the right kind?
'06 F350 TD, Softopper, airbags, AeroShield, coolant filter
'10 3665RE Hickory edition, wetbolts, Firestone LTs, Trimetric Battery Monitor, 4x100w panels & Morningstar TS-45, still tweeking.
