โApr-13-2014 08:49 PM
โApr-22-2014 08:55 PM
โApr-15-2014 09:55 AM
Dutch & Di wrote:
We've been using Potty Toddies for 18 years of fulltiming, in the same Carriage 5th wheel with the original tank, and have never had a problem. I drop one tap in the toilet after Dutch drains the black tank if the weather is 74 degrees or under. It it is above 75, I use two tablets. I buy them at Camping World. It is a no muss no fuss solution and what works for us. Hugs, Di
โApr-14-2014 11:07 PM
โApr-14-2014 07:13 PM
โApr-14-2014 06:48 PM
โApr-14-2014 05:53 PM
โApr-14-2014 03:41 PM
MM49 wrote:
The Thetford formaldehyde formula is the gold standard of blur juice. Don't even mess with the other perfumes. It's the only one thatโs designed to work.
MM49
โApr-14-2014 02:31 PM
โApr-14-2014 02:03 PM
โApr-14-2014 01:50 PM
โApr-14-2014 09:41 AM
Okie1 wrote:
Same here....rockhillmanor wrote:
You will get a myriad of answers on that question. From magic water softeners concoctions to ice to doing nothing. :R
For years and years there have been holding tank chemicals for marine and RV holding tanks. They were made for a reason. Your holding tank is not your mommas house sewage system. We have small pipes, bends and blades and sensors on the inside. All places for stuff to stick and clog.
If you don't want garbage stuck all over the inside of your tank and sensors, smells when you flush coming up into your RV, and don't want to experience clogs in the pipes and valve blades to ruin a good camping trip use this. All the others just add 'perfume' to the tank and does nothing but smell up your RV with a nasty perfume smell.
Thetford makes 2 types one to appease the greenies and this one. The labels look similar. Be sure to read the label and it says breaks down waste and powerful odor control.
20 years on the road now and my sensors always work and I have never had one incidence of sewer smells in the MH zip zero.:W
โApr-14-2014 09:31 AM
fairhaven wrote:
Happy Camper is the best stuff, easiest stuff I have found in 40 years. You can buy it from their web site 5starhappycamper.com. If there is a better product I am not aware of it.
โApr-14-2014 07:41 AM
โApr-14-2014 07:32 AM
