possible danger with wires ran inside axle to other side
Likes_to_tow
This happened to a friend a few years ago and was very hard to find. It was very intermittent and without the suggestion of some experienced camper at a campground he may never have found the problem. Check out this video. I'm pulling mine out of the axle today on the new 5th wheel I just purchased. You can run small plastic conduit or water pipe to the other side rather than use them as manufactured....inside the axle.
https://www.youtube.com/watch?v=21QFaEw3NCE
19 REPLIES 19
BB_TX
I wrapped multiple layers of tape around my wires where they enter/exit the axles shortly after I bought it in 2007. And I check those each year. So far no problems with wear on the wires.
MFL
Nomad II
Nomad II
That is a common problem, and has been for many years. I had that issue with previous FW. I could not believe how bad the wire inside the axle looked when I replaced it. Since most manufacturers are still using this method, you'd like to think they are using better wire/protected wire. Not likely, it should last through the warranty period without issue.
Jerry
Turn_Key
gbopp wrote:
Clicky
I wouldn't alter a new unit that is under warranty. I'm sure the manufacturer would use that as a reason to deny any related claims.
I would agree with "gbopp" here but it is something to look at once warranty has expired.
Also, I would think that this post would be better placed under "General RVing Issues" as it relates to all trailers. Just a thought.
Happy Camping!
Turn Key and DW
Bentley, One Very Pushy Chiweenie
Sunshine, One Crazy Pug (I Guess They All Are!)
'03 Chevy 2500HD, 4X4, X-Cab, Long-Bed
'14 Winnebago 26FWRKS ("Sunday Haus III")
Twin Kayaks, "The Ride" by Wilderness Systems
gbopp
Clicky
1320Fastback
They've been running brake wires thru the axle since electric trailer brakes were invented.
Thanks for the video.
1992 D250 Cummins 5psd
2005 Forest River T26 Toy Hauler
