โSep-21-2018 08:38 PM
โSep-22-2018 11:02 PM
Picinisco wrote:Learjet wrote:
I had a problem once and found out there is a check valve where the hose goes into the change over regulator. There is a brass fitting that is between the hose and the change over regulator on my unit.
Thank you for your answer. I had spoken to two rv service techs and neither of them told me about the check valve or backflow preventer in the system. One even told me that the backflow from bottle to bottle is normal.
I went through the set up again and found that there were indeed two backflow preventers it was just that they were in the wrong position.
Everything has been put back together correctly and gas is flowing as it should with no leaks from weepholes.
โSep-22-2018 07:38 PM
โSep-22-2018 05:05 PM
โSep-22-2018 04:26 PM
โSep-22-2018 09:27 AM
โSep-22-2018 07:48 AM
โSep-22-2018 07:10 AM
BarneyS wrote:
The position of the valve between the two tanks should stop the flow between them. If the pointer is towards the left tank, that tank should flow and the other not.
โSep-22-2018 06:30 AM
โSep-22-2018 06:27 AM
garyp4951 wrote:
Nothing should leak no matter what setting its on
โSep-22-2018 06:23 AM
