Pulsating lights
magictom
We are new RV'ers and have been using our 5th wheel in the backyard. It's hooked up to a 30amp power. Recently the lights starting pulsating and I'm not sure why. Also, things that we've turned on before that use more power, like the heat or electric fireplace, now shut everything down. Does this mean I need a new converter? Thanks in advance for any answers our way!
6 REPLIES 6
ScottG
ford truck guy wrote:
#1 - battery or connections
#2 - converter
This. If it's not the battery then that is the classic symptom of a failing converter.
Luke_Porter
Are the lights 12 or 120 volt? If they are 120 they have nothing to do with the battery or converter.
The fireplace is 120 volt, so it has nothing to so with the battery or converter.
Yep, actually drove to all of these places---in the last eight years. Missed Rhode Island and New Jersey.
TXiceman
Check for loose wires and loose grounds. If this does not clear it up, you may have a power converter going bad. Check the voltage at the converter output.
Ken
Amateur Radio Operator.
2023 Cougar 22MLS, toted with a 2022, F150, 3.5L EcoBoost, Crewcab, Max Tow, FORMER Full Time RVer. Travel with a standard schnauzer and a Timneh African Gray parrot
#2 - converter
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
robsouth
Check battery first. Most things depend on a good battery even if plugged into shore power.
"Sometimes I just sit and think. Sometimes I just sit." "Great minds like a think."
newman_fulltime
it could be several things from loose wires to a bad battery to a bad converter to low voltage at the plug you need a voltmeter and check the output of the converter and yourline voltage
