May-23-2015 02:14 PM
May-23-2015 09:47 PM
May-23-2015 09:32 PM
May-23-2015 06:51 PM
Baja Man wrote:
actualyy instructons do not say to remove wheels, only to jack up rear axle and use jack stands.
Question....why do the brackets only connect to one hole on each end of rail? Each end of rail has two bolts but only one connects to frame bracket?
That means there are only four bolts connect to rails and six connect only to sheet metal of bed. Correct? Doesnt seem right.
May-23-2015 06:19 PM
May-23-2015 03:22 PM
May-23-2015 02:30 PM
May-23-2015 02:29 PM
partsman01 wrote:
I have a hijacker I am fighting to get in now, it is the slider style and rails run the length of the truck bed, and on mine it had to be assembled then put in box and back of rail was set at 24 1/2" from end of box, then I squared the hitch side to side, so if yours is assembled when you put the hitch in and set the back rail correctly then the front rail has to be the correct distance.
You would then just make sure side to side is correct.
May-23-2015 02:24 PM
