โJan-16-2021 04:22 PM
โFeb-05-2021 03:23 AM
Crabbypatty wrote:
JRScooby Do you think that little crane could be a issue when loading TC?
Not at all it tucks in behind the wheel well. The bed is completely clear.
โFeb-05-2021 02:23 AM
โFeb-04-2021 05:16 PM
โJan-28-2021 04:23 AM
โJan-28-2021 02:37 AM
Crabbypatty wrote:
I have a Pullrite automatic slider 2600. All you need to do is pull the pins and its back to a pick bed again. Easy. We are a F250 CC Short Bed. Great hitch. If I ever find an inexpensive TC for a short bed I might get one. we will name it "Quickie" for fast trips and fishing.
The Pullrite is heavy, which is good but takes some moving to get it out. Either a winch in the garage or tree or what we have is a small bed crane from Harbor Freight. Cost $99. Tucks in behind the wheel on the side. Swing it around attach pump it up swing it over and let it down on saw horse. Good to go. Do the same thing for bring the 3000i into the bed.
โJan-28-2021 02:26 AM
โJan-27-2021 03:27 PM
ford truck guy wrote:cummins2014 wrote:ford truck guy wrote:
I used to run the Pullrite Superglide, which would leave my bed completely empty when removed...
That is, until I got a hernia removing it 1 year...
It does come in out pieces, but my its heavy at 275#.. I do not suggest at 70 you try to mess with that, UNLESS you keep it hitched to the trailer and remove the pins from the bed and raise it with the trailer..
We must not be the manly men some seem to be :B Then there is smart , and then there is , well you know . Iโm done lifting hitches , as suggested I will just get one of my grandsons to do it ๐
I'd like to think at 56 I still fall into that category ... but my body argues with me on a daily basis
โJan-27-2021 02:41 PM
โJan-27-2021 02:40 PM
And yet even after a hernia you have a Manly Man hitch.
โJan-27-2021 02:15 PM
ReneeG wrote:cummins2014 wrote:ReneeG wrote:Cummins12V98 wrote:ReneeG wrote:
Hensley's TrailerSaver BD3 removes easily and you can purchase a sliding base for it. We had the sliding base, but never used it.
What does the whole assembly weigh?
It comes apart for removal so the weight is manageable.
They all come apart , and are manageable. I know that , did it for about 9 years away from home when I needed the hitch out of the truck . Finally solved that problem with the Andersen, and have never looked back .
Good for you.
โJan-27-2021 01:55 PM
โJan-27-2021 01:34 PM
โJan-27-2021 01:32 PM
โJan-27-2021 12:51 PM
