Replacement Tires
Huckleby
So I need to replace all 4 tires on my 5th wheel due to cracking sidewalls. The size on it currently is ST205/70R14. This size is a bear to find and are quite pricey. I'm looking at going with ST205/75R14. I'm pretty sure I have room for them. Any thoughts on Radial vs Bias plys? Anyone know of a cheap source for trailer tires?
1992 Salem by Cobra 21F Fifth Wheel
Reese Classic 15K Hitch
2011 GMC Sierra 1500 crew cab shortbox
5.3 liter, Volant cold air intake & headers
21 REPLIES 21
Huckleby
The 5th wheel is only a 21'. The current tires are BF Goodrich Lifesaver Radial ST. Load Range C. When I look at the tires now I know for sure I would have plenty of room for the 75 series. It would also help with my nose high attitude when hooked up.
time2roll
TucsonJim
Tirerack.com lists a few in this size. Here is a Goodyear marathon as an example:
Tire Rack
2016 Ford F350 Turbo Diesel SRW 4x4
2017 Grand Design Reflection 297RSTS
2013 Ford F350 Turbo Diesel SRW 4x4 (Destroyed by fire - 8/29/16)
2014 Grand Design Reflection 337RLS (Destroyed by fire - 8/29/16)
TucsonJim
If you'll provide a little more info, we'll try to help. Look at the side of the tires. What load range are they? I would imagine load range "C" or "D". Also let us know the maximum weight and tire pressure listed on the side of the tires.
Jim
Me_Again
the bear II wrote:
You might have better luck going to Light Truck (LT) type tires instead.
In 14" size????? Chris
the_bear_II
DavidP
Those are very small tires for a 5th wheel. What size trailer do you have? What brand tires are you replacing?
