Replacing couch ?
Bigmoss
As you can see from my sig I bought a used 5er, the unit is mint except the couch springs are loud as yell and have seen better days. It is one of the units you lift and pull forward and it drops flat as a bed. My fresh water tank hot water tank and pump are under it.
On quick review it just seems to be some lag bolts that hold the upper and lower parts of the couch in place I was just wondering being the unit is a 97 is there a site I could get a replacement from easy that will bolt right in ?
Thanks
2016 Ford F-150 Screw Lariat Short Box
2015 Jayco Eagle HT 27.5 RLTS
Reese 30051 Hitch with Revolutionary Pin
11 REPLIES 11
goducks10
I have that type of couch. You could give Northwood Manf a call and see what they might sell one for. Too bad you weren't closer as I'd sell you ours. We are going to replace it with recliners. Don't need the bed function of it.
KSadler1
----deleted----
2008 Ford F250 XLT Super Duty SB Crew Cab 6.8L V-10 4x4 4:10
(former 5er owner)
Nutinelse2do
Try Dave & LJ's in Washington State if you are a West Canadian. They will be more than happy to help. They replaced and installed a couch in our old DP for someone in BC that bought it. They are very aware of the Canadian Safety Standards ( which are tough! ) and made sure it was up to code. Our DP had " stuff " under the couch also.
Good Luck.
Living Our Dream
MTHRSHP - 2006 KSDP 3912
Cummins 350ISL...Spartan Chassis
ESC POD - 2019 Ford Ranger XLT FX4
Zippy Scoot- 2018 Honda PCX 150 on an Overbilt Lift
Shredder at the Rainbow Bridge - You Will Always Be With Us
Goostoff
Just noticed you siad water heater was under there too. With that venting outside for gas and such my options are going to be very limited without major mods.
1993 Chevy C3500
2005 Cedar Creek 34RLTS
Goostoff
I would look into a love seat hide a bed option. The one in our creek looks like there may be enough room under it to not interfer with the water tank. If not maybe go to the furnature store and look into a regular love seat. I would bet if you take the fabric off the bottom it would slide right over top of everything. Worst case you may need to modify the one board on the bottom in the back. Who cares if you mess up the fabric back there. You will never see it anyway.
1993 Chevy C3500
B_O__Plenty
The problem the OP mentioned wasn't in finding just a couch. The couch in their trailer is open underneath and covers their pump, water heater and fresh water tank. It's actually just a seat cushion and a backrest not a couch as we know it. A standard couch will not work. I had the same thing in an early 90s TT I once owned. My suggestion would be to take it to an upholstery shop and have it rebuilt and recovered. That maybe your only solution.
B.O.
Former Ram/Cummins owner
2015 Silverado 3500 D/A DRW
Yup I'm a fanboy!
2016 Cedar Creek 36CKTS
Deb_and_Ed_M
Ironically, we're going to go look at a used 5er today - and the woman who owns it said she replaced the original couch, by going to our local furniture store - where she found a nice jackknife couch in a complimentary color! Said it's much nicer than the original. If we end up buying it, I'll tell you who makes the couch.
Ed, Deb, and 2 dogs
Looking for a small Class C!
wcferb
Will a futon fit over the tank and pump? You would still have a bed for hunting. Might even be able to construct the frame, if yoy are handy. And then buy the pad.
Bigmoss
Yes we use it as a bed especially during hunting season
Dick_B
Do you use the couch as a bed? If not what about putting in something different/better?
We opted for two recliners instead of a couch when we bought our rig.
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
chris3403
Good luck with that. Earlier this Summer we tried replacing ours going to 5 or 6 different places in the Elkhart area before finding one that we wanted at Bontragers in White Pigeon, Mi
They removed the old one and put the new one in but they would not bolt it to the floor. They did take the brackets off the old one and gave them to us to put on.
I've been to all 50 States but my RV hasn't.
