Sailun S637 on 3200lb Capacity Wheels
On_theProwl
I'm really wanting to do the Sailun S637 tire upgrade on our fiver when we take delivery, but I'm worried about the wheel capacity.
I've been told that I would be ok to run 95-100psi in these wheels with metal stems. Fiver is a '16 Jayco 326 BHQS with a gvwr of 14k.
Thoughts?
2016 Jayco Eagle 325BHDS
2014 Ram 2500 CC 4x4 6.7 Cummins
22 REPLIES 22
NC_Hauler
On theProwl wrote:
I confirmed with local tire dealer today. He says that it is no problem running 110psi in that wheel with those tires. He states that overloading the wheel weight rating is what will cause wheel failure. I've dealt with him for years and he knows his stuff. I'm not saying he's right or wrong, but i do value his opinion and feel it trustworthy.
I also know between this forum and the Jayco forum that several are running the same setup on the same wheels.
Then the wheels must be rated for 110 psi..The 2016 Jayco Seismic 4112 had 3 axles and a GVW of 21K..Those wheels will take 110 psi.
Jim & Kathy, (Boxers, Buddy & Sheba)
2016 Ram 3500 DRW Longhorn 4X4/CC/LB/Aisin/4.10/rear air assist ...Pearl White.
2016 DRV MS 36RSSB3/ W&D/ slide toppers/ DTV satellite/ 5.5K Onan propane gen.
B&W RVK3600 Hitch
Fulltiming in WV & TX
USAF 71-75 Viet Nam Vet
On_theProwl
Drifter1959 wrote:
I purchased wheels and tires and I'm keeping the take offs so that I can swap back when I trade or sell the current 5er. I think it was about $1235.00 total, mounted, balanced and delivered to my house. Well worth it IMHO.
The wheels are a direct match in the stock wheel appearance and the tires are 235-85R16 "G" Sailun tires.
Would you care to share a link as to where you purchased?
On_theProwl
fj12ryder
I run my Sailun tires at 95-100 psi., but that's 15-20 psi over your wheel rating. Personally I wouldn't run mine at less than 95 psi. And I don't know that I'd feel comfortable running my wheels at 25 percent more pressure than rated capacity. Who told you you could run 95-100 psi. with those wheels? If it was the dealer, make sure you get that in writing.
The sidewalls are really stiff and running at 85 psi. might not be an issue, but I'm not a tire engineer and can't really say.
Howard and Peggy
"Don't Panic"
Drifter1959
Mule: 2016 RAM Mega Cab Dually 4X4, RAM Puck w/ Demco Hijacker 21K Autoslide, Laramie, 6.7, Aisin, 4.10's, 51 Gal Midship Titan Fuel Tank.
Wagon: 2015 Jayco Pinnacle 38FLSA, Sailun G's, Center Point Air Suspension, 572 Watts Solar w/4 T-145s.
NC_Hauler
Then, I would think, wheels are only rated to 80 psi.. but could be wrong
B&W RVK3600 Hitch
On_theProwl
NC Hauler wrote:
Wheels may already be rated to 110 psi..crawl under 5er and see if information is etched on backside of the rim..
You could also call Jayco and they'll be able to tell you...
Jim
Wheels are stamped with 3200# capacity and no psi limits.
NC_Hauler
Jim
B&W RVK3600 Hitch
