Sailun Tires ?
caysea7254
Just got our Sailun tires on our 2015 337 RLS Refection. Question is our Westlake psi we kept at 80, do these need to be any more than that? Thanks Tara
Steve & Tara Smiley
2022 3500HD Sierra GMC
2017 Grand Design Reflection 27RL
42 REPLIES 42
blofgren
I'm running mine at around 105 psi too, mostly because my little compressor won't go any higher. My experience is similar; great handling, good ride, running cool, and wearing evenly and very slowly! :B
2013 Ram 3500 Megacab DRW Laramie 4x4, 6.7L Cummins, G56, 3.73, Maximum Steel, black lthr, B&W RVK3670 hitch, Retrax, Linex, and a bunch of options incl. cargo camera
2008 Corsair Excella Platinum 34.5 CKTS fifth wheel with winter package & disc brakes
mapguy
kzspree320 wrote:
second chance - Thanks for sharing your results running at 105 psi. Nothing better than hearing what has actually worked long term in the real world (not just inflation tables and charts). I appreciate it.
Load and inflation chart published by Sailun plus ideally the weights of the individual trailer wheel positions allows a real world starting point for reduced by load inflation level. Trailers usually need 5 to 10 psi above the table.
cummins2014
Miles Away wrote:
Can anyone advise where one can purchase Sailum Tires? There does not seem to be any dealers in the US.
Big O tires carry them here in Utah. Simpletire online carries them. I got a price match from a local tire dealer here in Utah other then Big O. Can't imagine any major tire dealer not being able to get them.
Miles_Away
M & M :C On the road again!
2007 GMC 3500-SRW-Duramax-longbed-4X4
2008 Keystone EVEREST 348R 5th wheel
2002 SUNDOWNER gooseneck horse trailer
kzspree320
Dennis12
Seems like a lot of work to me. I'd talk to the tire manufacturer before I'd take someone elses word.
Dennis Hoppert
Second_Chance
kzspree320 wrote:
I am assuming that yours, like mine, are probably the 235/80 (or 85) -16 G rated tires. If so, the maximum pressure is 110 psi. I am running my new Sailuns at 105 psi. The problem with going way under the maximum pressure is the sidewall deflection when you are backing up sharply. I am also assuming you checked your wheels to make sure they are rated at 110 psi. Good luck.
Per the trailer experts (they build and repair BIG trailers) who installed the tires and going by my most recent weight ticket, I was instructed to run the G-rated Sailuns on my 337 at 105 PSI. That's what we've been doing for 10K miles. The wear is even, the TPMS says they run cool, and the rig handles very well.
Rob
U.S. Army retired
2020 Solitude 310GK-R
MORryde IS, disc brakes, solar, DP windows
(Previously in a Reflection 337RLS)
2012 F350 CC DRW Lariat 6.7
Full-time since 8/2015
caysea7254
kzspree320 yes they are the same tire as yours. And yes we talked to Grand Design and yes the wheels are rated for 110. We assumed since psi was 110, that we should have them around 95 . We have no idea about tire weight. Thanks to all of you for your info. WE appreciate it! Tara
Steve & Tara Smiley
Lantley
Wild Card wrote:
Gotta know weight loading on the tire. Then adjust pressures accordingly.
That sounds good in theory, however does that mean you are weighing each tire individually?
Wild_Card
2015 Ram 3500 Dually
Sundowner 2286GM Pro-Grade Toyhauler
Lantley
Air to max pressure 110 PSI. I want maximum capability. I'm not trying to dial in the pressure to the weight. I think that's a problematic approach.
fj12ryder
What amount of weight is on the tires? That will help determine what pressure to run them at. I only have about 2500 lbs. on each tire and run around 90-95 psi. Some folks run lower, but I would feel uncomfortable running under 90 psi. But that's just me.
Howard and Peggy
"Don't Panic"
kzspree320
