Sealing Holes...
JD_Montana
I've recently purchased a new Montana & have noticed that there are quite a few access points for critters (rodents, etc) in the propane storage compartments. There's a huge hole where the front hydraulic legs are located, which would be very easy access for anything to climb in. I'm worried that from there something can climb through the holes that are there for wires/pipes, etc.
Thoughts? Should I be sealing these with foam or something?
Thx!
10 REPLIES 10
Dayle1
Happy Prospector wrote:
Why in the world would you buy a new trailer and then afterwards be concerned about all unsealed access holes? If the people at Montana could not be bothered to seal up all the access holes that mice, rats, squirrels, and what ever else can get into your RV and destroy it, I would hate to see what the builders buried in the walls and where you can't see.
But the people at Montana don't live in or own the RV, so their perspective is different than the new owner.:S If you buy a brand new house and the builder didn't install window shades are you going to leave it that way??:E
Larry Day
Texas Baptist Men-Retiree Builders since '01
'13 Silverado 3500HD LT 2wd CCSB SRW, custom RKI bed
'19 Starcraft Telluride 292RLS
Rig Photos
alexleblanc
cpaulsen wrote:
I used spray foam on all the openings.
bingo, same here. I live out in the country and we have ton's of field mice so I'm constantly keeping an eye on that and making sure there are as few entry points as possible.
TV - 2017 F350 CCSB SRW Platinum 6.7 + 5er - 2021 Grand Design Reflection 311 BHS + B&W Companion
On Order - 2022 F350 CCSB SRW Platinum 6.7
cpaulsen
cpaulsen
blofgren
I agree with this. We looked at several new Montanas a couple of years ago and were very close to pulling the trigger until I noticed all of the huge openings all over the trailer. We had rats get into a fifth wheel that we had several years ago which was not pretty, and I could easily see that happening with what I saw with those trailers. I just couldn't see paying what the dealer was asking for the trailers and then have to deal with that.
To the OP, I would stuff brass wool as tightly as I could into the holes and then seal them up with spray foam. Be sure to take your time and look over the trailer carefully because you certainly don't want to miss anything. Good luck.
2013 Ram 3500 Megacab DRW Laramie 4x4, 6.7L Cummins, G56, 3.73, Maximum Steel, black lthr, B&W RVK3670 hitch, Retrax, Linex, and a bunch of options incl. cargo camera
2008 Corsair Excella Platinum 34.5 CKTS fifth wheel with winter package & disc brakes
Happy_Prospecto
Kevin
Retired, Fulltime RV'er, 1999.5 F350 4X4 CC Diesel Flatbed
2007 Alpenlite Defender Toyhauler, 2019 Polaris Ranger
Bob, the Yorkie Terrier helping me prospect til the money runs out
Shadow_Catcher
Propane is heavier than air, screen but do not seal or it could go boom.
Rolling_Condo
Use bronze wool, won't rust.
'90 GMC R2500 7.4L w/ Gear Vendor OD
'90 Avion 34V
Cummins Onan P4300ie
Pro Pride 3P
Prodigy
rhagfo
DickOK wrote:
Spray foam.
DO NOT seal the bottom of the propane tank bays!!!! You can seal the openings for the cross over pipe, and over head openings.
DickOK
Spray foam.
Dick OK
Ed9824v
steel wool type material is a good deterrent.
Ed So.Calif
1950 Ford F1 street rod
1968 Baha Bug with 2.2 ecotec motor 170 hp, kingcoil
2000 National Sea Breeze 5th wheel trailer
1998.5 Dodge 2500 4x4 Cummins,4.10 gears,turbo,trans,injectors,oil cooler,lockers,edge EZ, 35" BFG's, air dog lift pump etc.
