May-12-2018 05:16 AM
May-20-2018 09:16 AM
May-20-2018 09:00 AM
donn0128 wrote:
Get real!
I have approx 150 pounds less weight with no slider hitch.
May-20-2018 08:28 AM
donn0128 wrote:
Get real!
The difference between a short and long bed is approx 2 feet. That 2 feet allows me to carry air compressor, extra stuff, fishing gear full sheets of plywood all with the tail gate closed and stuff flat on the floor!
With my fold a cover in place and open, I have 2 feet of space under cover. I have approx 150 pounds less weight with no slider hitch. I can take my hitch out in two pieces by my self. Short bed trucks ARE a rarity in 2500 and 3500 configuration. Go look in dealers lots and try to find one! Like I said "YOU MAY NEED OR WANT" I did not say you must have.
The OP is totally free to do what he wants. It is his money afterall. All I was trying to do was give hom things to think about, not get into an argument with you.
May-16-2018 05:18 AM
MFL wrote:SugarHillCTD wrote:
Maybe I need to change my signature to say standard bed.
Looks like you've got it covered John, sb will work for standard bed also.
Jerry
May-16-2018 05:04 AM
May-16-2018 04:53 AM
May-15-2018 04:53 PM
May-15-2018 12:25 PM
donn0128 wrote:
Ypu can tow with a sjort bed. The trade off is,,,,,,
You loose 2 feet of useable cargo space,
You cannot carry a sheet of plywood or sheetrock with the tail gate closed,
You may need or want a much heavier slider hitch, thereby reducing your available cargo capacity,
You likely could not fit the truck with a folding bed cover,
Rarely have I ever seen a 3500 short bed truck. Which indicates to me your interested in a 2500 series truck? Which is fine as long as your looking at a short, light fiver. Once you go over about 12,000 pounds gross your going to want a 3500 series truck.
May-15-2018 10:05 AM
May-15-2018 06:56 AM
Dave H M wrote:
I just do not understand the issue of "you can't haul a full sheet of plywood or sheet rock in a short box and close the tail gate".
I haven't seen anyone preface this statement with "I am a sheet rocker, or I haul a lot of plywood with my TV".
May-15-2018 05:03 AM
May-14-2018 06:34 PM
May-13-2018 05:38 AM
May-13-2018 05:04 AM
