Jul-31-2016 09:07 PM
Aug-07-2016 02:16 PM
Aug-04-2016 06:35 PM
Aug-04-2016 05:39 PM
Dano1955 wrote:buckarooman wrote:Bowti wrote:
Again, your AAV has nothing to do with venting your holding tank. You have people telling you your holding tank needs to be vented. Find the vent and make sure it is not plugged.
I realize that the aav doesn't any thing to do with the vent, I only have one roof vent and it's in the back of the trailer on the bathroom gray water tank. There's no physical way that the tanks are tied together the kitchen tank has only a aav an nothing more. The roof vent in the back vents the one gray tank and best I can tell the black tank, I can't see how they would have ran a vent line from the island sink to that roof vent with out it being under water.
Your island sink will be vented. Since there is only one roof vent, all the waste tanks should vent out to that single outlet
Aug-04-2016 05:36 PM
Aug-04-2016 04:37 PM
Aug-04-2016 03:19 PM
Aug-04-2016 02:41 PM
buckarooman wrote:
I wish I had a roof vent haha stupid island sink doesn't have one so the tanks only vented with the aav
Aug-04-2016 01:50 PM
Not sure if you have found the problem yet, but from what you have posted so far it sounds like your holding tank vent is plugged. The Air Admittance Valve's only purpose is to keep your drain trap from being siphoned dry, which would allow fumes from your holding tank to stink up the place.
Your sink drains good with your tank drain valve open, and gives you problems with it shut so that points to your holding tank vent being plugged. This it what Old B was getting to.
Get on your roof and find out what pipe leads to the tank you are having problems with and unplug it.
Aug-04-2016 11:09 AM
Aug-04-2016 11:06 AM
Aug-03-2016 06:48 AM
Aug-03-2016 06:03 AM
Aug-03-2016 05:56 AM
Aug-02-2016 08:50 PM
