Slide hydraulic reservoir
usnret
I need to top of the hydraulic reservoir on my Cardinal fifth wheel. Is ok to use hydraulic fluid from an auto parts store like Auto Zone?
Thanks in advance.
Jim
USNRET
Jim & Judy
2009 Ram 3500 Dually LB
2011 Cardinal 3425RT
The Meandering Maddox's Blog
The Call to Serve
"Heaven must need a hero"
7 REPLIES 7
usnret
Thanks to all for your advice and comments.
USNRET
Jim & Judy
The Call to Serve
laknox
As long as it's down, why not top off with the stuff LCI recommends to fix the "popping" noises, even if you're not having them? Some sort of additive that's usually found at a Cat dealer. Sure can't hurt anything.
Later: I remembered that it's called "anti-stiction" fluid.
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
ChuckSteed
You need to,look at the color of the fluid..
Not all were filled with transmission fluid..
If the fluid c9,or is honey brown then you need AW32 hydraulic fluid that you can get in an auto store or Wally World
If fluid is red then service with previous posters Lippert PDF.
Lippert says donโ€™t mix fluid types
jtaylor1920
Here is Lipperts recommendation.
Here is a link to the tech sheet.
https://www.lci1.com/assets/content/support/technical-information-sheets/Leveling%20and%20Stabilizat...
Note: Moderator edit to enlarge picture for readability.
John, Laurie & the 2 Schnauzers (Mazie & Obi)
2016 GMC Duramax Dually
2018 Cardinal 3350RLX
B&W Companion Hitch
Old-Biscuit
ATF IS the standard fluid for hydraulic operated slides
Slides should be retracted when adding fluid to reservoir
cummins2014
Thanks in advance.
Jim
Thats what I use , I just bought a quart bottle of Johnsen's Hydraulic Jack Oil from O'reily's . I can see that mine is not ATF, it fairly clear. Been using Johnsen's in mine for several years.
Now if I would pull off one of the hydraulic hose that is leaking in the fitting ,and get the fitting replaced I probably wouldn't have to keep adding periodically :B My bad !!
enblethen
Look at the unit spec sheet. It should say automatic transmission fluid in most.
Make of the slide unit would help.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
