slide out scratching floor
quadley
How do you stop the slide out from scratching the floor. Is it just a simple adjustment or is there more to it?
8 REPLIES 8
missourijan
After trying the other good suggestions by other posters and IF you can't find an answer order some "slide slickers". They are long vinyl things that lay on the floor as the slide comes in and prevent scratching. I ordered some after we removed the carpet in the living room and adjusting the slide did not solve our scratching problem. I think I ordered them from Tweety's
DReisinger
Once it moves about a couple inches, I put a throw rug under the leading edge to protect the laminate flooring I installed
bbaker2001
I am thinking of having slide removed for same reason
Is it very expensive
BB from California
2015 Ram 3500
2001 Cardinal
best friend is my wife ๐Ÿ™‚
alexleblanc
make sure you sweep or vacuum the floor properly before you ever close the slides, I had a few rocks make huge gouges in my floor while opening the slide on my last unit, since then I always am anal about cleaning the floors before closing the slides. otherwise the slide bottom shouldn't be touching the floor but with so many designs out there I can only comment on the ones I've owned or seen myself.
TV - 2017 F350 CCSB SRW Platinum 6.7 + 5er - 2021 Grand Design Reflection 311 BHS + B&W Companion
On Order - 2022 F350 CCSB SRW Platinum 6.7
handye9
Could be something stuck under the slide, could be a screw sticking out, could be an adjustment needed. Hard to say without seeing it.
I had a slide scratching the floor and it was the head of a screw that had backed out. The slide had to be removed to fix it.
18 Nissan Titan XD
12 Flagstaff 831FKBSS
Wife and I
Retired Navy Master Chief (retired since 1995)
ScottG
There are som many different designs that it's impossible to say without more info and a pic.
There probably is something that can be done though.
garyemunson
My slideouts (Winnebago Vista) have carpet covered blocks attached under them that slide on the vinyl floor. One of mine had lost one of it's two attachment screws and was wobbling around. I caught it right away and fixed it before it did any appreciable damage. Made me aware I need to keep an eye on them and I expect sometime in the future replacing the carpet is in the cards. Not sure what your's uses to slide across the floor without marking.
Lwiddis
Make, model, year? Picture would help or what do you see or feel?
