Slide Out
bmcdonald
We have a 2008 Cardinal with 3 slides. The bedroom, kitchen slide goes out first, second but living room slide gets almost out it stops. We wait a few minutes then goes on out. No problems at all coming in. Someone told us the 'manifold' could be bad? Plenty of fluid in it. Any idea's what possibly could be? thanx.
18 REPLIES 18
donn0128
The big slide is always the last to move. Shear size and weight dictates that. Mine do the same thing. The main slide starts, stops while the smaller slides ove in. When there in the main slide finishes. Totally normal, unless the k0tor stops. Then there is something wrong.
john_bet
The auto reset circuit breaker for the pump motor is tripping then resetting after a few seconds or minutes. Mine does that except in reverse. It trips upon closing. The answer is to change the c/b to a larger size. I have not done that as of yet, but plan to.
2018 Ram 3500 SRW CC LB 6.7L Cummins Auto 3.42 gears
2018 Grand Design 337RLS
bmcdonald
The fluid is at the correct level.
RustyJC
How much hydraulic fluid is in the reservoir when the 3rd slide stops on the way out?
Rusty
2014.5 DRV Mobile Suites 38RSSA #6972
2016 Ram 3500 Dually Longhorn Crew Cab Long Bed, 4x4, 385/900 Cummins, Aisin AS69RC, 4.10, 39K+ GCWR, 30K+ trailer tow rating, 14K GVWR
B&W RVK3600
