My main living room slide has always dropped a little into position when it just reaches full extension but here lately it seems to struggle a little more to get out right at the end and then seems to drop a bit more than it used to at full extension.
I looked under the slide and it doesn't appear that they have moved out of adjustment. There is a adjustment bolt that won't allow the slide to drop past the way it was set up new. 2006 Cardinal 362BHS. The hydraulic fluid looks like it always has, need to pull the manual out and see where full is, there is a line on the canister...... The fluid is just under it but not sure if that line even means anything.
I pulled the slides out today and they came out all the way, just seemed to struggle a little more than normal and there at the end drop more than normal into place.
Any thoughts, thanks
Jeff,Julie,Amber,Brandon,and Casey and Winston ( our 5 year old Golden ) and Bruno the Pug. We now have an English Cream, white Golden Retriever as well.
2015 Keystone Montana Mountaineer 356TBF
2005 Chevy duramax dually
