slideouts
chips47
we Have a 2011 Mountaineer 347THT> Slide outs operate by remote control or button switch inside by control panel.currently the inside switch will not open or close slides, only the remote.have checked regular fuses,2 fuses in converter box and auto parts store confirmed battery is good. Now what to check?need help
2 REPLIES 2
lanerd
Exactly. You do have a multimeter...right? Just pull out the switch and measure the voltage to see if power is getting through the switch. If it does, then your problem is down stream from there.
Ron
Ron & Sandie
2013 Tiffin Phaeton 42LH Cummins ISL 400hp
Toad: 2011 GMC Terrain SLT2
Tow Bar: Sterling AT
Toad Brakes: Unified by U.S. Gear
TPMS: Pressure Pro
Member of: GS, FMCA, Allegro
RETIRED!! How sweet it is....
Winged_One
Replace the switch. If your handy, check power in and out of the switch to see if you have any.
2013 F350 6.7 DRW SC Lariat
2011 Brookstone 354TS
Swivelwheel 58DW
1993 GL1500SE
Yamaha 3000ISEB
