Slider or not for 2011 F350 srw 7ft bed
TxHitchHiker
Considering a different TV. Is a slider necessary for the 2011 F350 srw. I have a 2012 HitchHiket with standard pin box. Thanks in advance for your help.
15 REPLIES 15
cummins2014
djousma wrote:
I have a 2016 Ford F350 short box, which by the way is 6.75'. I opted to go with a slider, when I bought my Cardinal, mostly because I was new to 5th wheel towing. With that said, after 2 years of towing now, I'd still go with a slider. Let me qualify that, an AUTOMATIC slider. I went with the DEMCO 21K Hijacker autoslide, and I never have to make a determination on whether or not, I should engage the slide or not. If it's manual, as many of you have stated, it might as well be fixed, because those accidents happen at inopportune times....times when you don't think the slider is necessary.
My next truck will be an 8' bed to get the larger fuel tank, and at that time I'll switch to a fixed hitch, probably a B&W companion that fits the Ford Puck system.
I agree, no sense in buying a fixed slider, in most likelihood a mishap is going to happen unexpected, and not used to start with. If someone things they are not aware enough, or in conditions where a slider is needed, then go the automatic ,and be done.
djousma
Dave
2016 F350 Lariat 4x4 FX4 SRW CC SB 6.7 Magnetic Metallic
2017 Forest River Cardinal 3850RL
cpaulsen
Have a Pullrite in my Ford short bed and use it all the time....it is the auto Superglide.
cpaulsen
RVcrazy
We have a Hitchhiker we tow with a SB Chevy. We use a Pullrite automatic sliding hitch. Worth every dollar!
Njmurvin
Someone has to say it ...
I have a Pullrite SuperGlide and with all the stuff you have to think about when towing, I am happy to say worrying about trailer-cab contact is not one of them. Best RV money I ever spent (with the possible exception of my exhaust brake).
2020 Chevy Silverado 3500HD Duramax 4x4 Crew Cab Standard box
2011 Arctic Fox 27.5L
cummins2014
Me Again wrote:
For all those that say you do not need a slider, ask them to warranty that you will never take out a rear window and/or dent the cab. Chris
Friend with a 2011 Superduty, and a newer Montana fifth wheel, he has the slider, but it didn't prevent him from denting the cab, backing up at an angle , truck tire went into a low spot, and you know the rest fifth wheel came in contact with the cab.
If he would have used the slider this would not have happened ,but I have watched him back into our hunting campsite off road, and I would have never thought he would hit the cab, always seemed like plenty of clearance.
The comments I have never used my slider is pretty valid, I too had a slider, that I never needed, but what happened to my friend could have been prevented, but I don't think many will see it coming.
I have the same setup ,but a Ram truck, I have never needed the slider either, so now I have the Andersen rail mount, but very aware of what happened with my friend, and will take the steps to prevent his mishap .
phillyg
All Ford short beds are 6.5' as far as I know. I have an auto slider and the front corner of the Montana still gets rather close to the truck cab. OTOH, the 2014 Wildcat didn't need a slider, so you never know till you hook up.
--2005 Ford F350 Lariat Crewcab 6.0, 4x4, 3.73 rear
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
dave17352
I had a slider for years and only actually used it a couple times.
NOW 2017 Leprechaun 260ds
2005 Forrest River Cardinal 29rkle FW
1998 Lance 980 11'3" TC
2017 CHEVY 3500 SRW 6.0
B@W turnover ball @ companion Hitch
Honda eu3000 generator mounted on cargo rack
Crestliner 1850 Fish Ski boat mostly fishing now!
MFL
Nomad II
Nomad II
Well Chris, no one will warranty that you won't have an accident, except your insurance agent. You have to pay for that warranty/insurance Anyone can have an accident, even when not towing. However when towing, any type trailer, more caution/awareness is needed. I know you need a slider, but because of your setup, rather than your ability, or actual need.
Jerry
Me_Again
MFL
Nomad II
Nomad II
Most later model FWs with standard pin box, are actually somewhat extended. My neighbor has a HH with square front, and 6.5 bed 2012 GM truck. He has a B&W Companion non-slider. He gets pretty twisted at times, not the best at backing, but no issues with cab clearance.
I have a non-slider in my 13 Ford SuperDuty 6' 9" bed. The pin center is 40.5 inches behind the cab. My FW does have EASY TURN, which is the rounded front cap. I keep aware, in tight turns, forward or back, but have never come close to hitting the cab.
To answer your question, "necessary for F350", NO, but drivers ability/awareness can vary.
Jerry
4x4ord
Those I know who have sliders never unlock them. I've never had or wanted a slider.
2023 F350 SRW Platinum short box 4x4.
B&W Companion
2008 Citation Platinum XL 34.5
newman_fulltime
standard pin box or extended pinbox big diff
jerem0621
Depending on your weight I would consider a Sidewinder and a standard fifth wheel hitch or an Autoslider.
Thanks!
Jeremiah
TV-2022 Silverado 2WD
TT - Zinger 270BH
WD Hitch- HaulMaster 1,000 lb Round Bar
Dual Friction bar sway control
Itโ€™s Kind of Fun to do the Impossible
~Walt Disney~
