Slides with cables
sk734
How are slides with cables holding up? I am looking at some lightweight 5vers like Cougar that have them.
26 REPLIES 26
SDcampowneroper
We have seen 2 lemon law enforcements about cable operated slides on a TT. That co. was out of business quick.
I would be hesitant about a cable system, as they do require pulleys, cables stretch,fray, do not always level wind.
Look at pop ups that necessarily use cables. Most last for many years with no trouble, however when there is a problem it renders the unit unuseable as there is usually no way to open it any other way
Hyd., rack & pinion, geared slides can be moved even without the motor working.
Me_Again
Schwintek is at the bottom of the list from everything I have heard about it. We have two LR hydraulic slides and bedroom has the cable system. No problems to date. Chris
colliehauler
goducks10 wrote:
Can cable slides be partially opened and closed vs Schwintek type that need to be fully opened and closed so as to not get out of sync?
Yes, no problems.
goducks10
old_guy
not all TT are having problems but the biggest problem we had at the dealership was the cables would eat through the grommets and into the slide and then the cable would break
westernrvparkow
Over the years, we probably have had 3 times as many units with cable slide problems than with gear or hydraulic mechanisms. That being said, we were able to jury rig repairs on several of those rigs with cable slides so they actually worked, but were never able to do anything but use the override functions to shove back in the others. One big problem I remember vividly is a customer who's cable jumped the pulley, and really did some damage to the slide structure. But I don't think I would walk away from a rig I otherwise want over the slide mechanism. I think with proper maintenance and inspection, they all work pretty well.
salem
I hope sk734 doesn't mind me jumping here, but just out of curiosity, what problems do some people have with the cable slides? I know they haven't been on the market that long and I too am curious.
filrupmark
3 years on our bedroom slide with no problem. I like it.
2004 Ford F250 Super Duty 6.0 Diesel, Bilstein 4600 Shocks, 16K B&W Patriot, Michelin M&S
2014 Augusta Flex AF34RS Trailair Tri Glide pinbox,
JT Strong Arms , Bridgestone R250'S, KYB Monotube Gas shocks
Finally a smooth ride !!!
Arcamper
Our Montana has one cable slide in the bedroom and so far no issue at all.
2016 Montana 3100RL Legacy(LT's,Joy Rider 2's,disc brakes)
2014 Ram 3500 DRW Laramie Cummins/Aisin 14,000 GVWR
2014 Ford Expedition Limited, HD tow pkg
2016 Honda Civic EX-T
1999 Stingray 240LS
1994 Chevy 1500 5.7 PU
2018 John Deere 1025R
B&W RVK3600 Hitch
Allworth
Ten years without problems.
Formerly posting as "littleblackdog"
Martha, Allen, & Blackjack
2006 Chevy 3500 D/A LB SRW, RVND 7710
Previously: 2008 Titanium 30E35SA. Currently no trailer due to age & mobility problems. Very sad!
"Real Jeeps have round headlights"
Bob_Sue
My fiver has three cable slides. All I have had to do in the 5 years has been to adjust the slack in the cables from time to time. Although others have had numerous problems. But I also see other systems having their fair share also.
Bob&Sue
2021 Cedar Creek 34IK
2011 Ford F-250
6.7 litre PSD
Pullrite Superglide
DutchmenSport
My Outback TT (also a Keystone product, same as Cougar), has a cable driven closet slide in the bedroom. We've had the trailer over 4 years now and not a hint of problems.
