Sloppy gearbox????
SpurHntr
While giving my new (to me) fiver a once over this weekend, sanitizing h20 system etc I noticed something when using the landing gear...
A super "sloppy" gearbox - twisted quite significantly on the post.
Lugs intact but I bet it rotates 20 degrees on there.
Looks like its Lippert.
Looks like the body of the gearbox is plastic.
Looks intact.
Retracts/extends fine.
This something to be urgently concerned about?
Despite a search, and the fact I've never tore down landing gear, I'm not certain how the system works.
Considering swapping out existing gearbox with aluminum one.
Any input appreciated.
TIA
'08 Newmar Kountry Star 3916, 400ISL Cummins
'17 F250 Diesel Platty SRW Crew 6.75' bed
'17 JKU Rubicon Recon, LoD flat towable Destroyer bumper.
Blue Ox, BB, PP TPMS, Ranger EV
6 REPLIES 6
mileshuff
Motor on mine is loose on its mounts by design. Moves all over the place!
2014 Winnebago 26FWRKS 5th Wheel
2007.5 Dodge 2500 6.7L Diesel
2004 Dodge Durango Hemi 3.55 (Used to tow TT)
SpurHntr
Thanks BillB
That makes more sense now, and makes me more relaxed about my findings.
Appreciated.
BillB3857
SpurHntr wrote:
Is that motor/gearbox all that's preventing landing gear collapse?
Looks a bit "flimsy"
Or are there internal features within the landing gear that prevent collapse, say, should the motor's shaft shear off?
The landing gear are long screws with bevel gears at the top. The legs have captive nuts that move up/down as the screw is turned by the motor through the bevel gears. Even if the motor or cross shaft were to fall off, the legs won't collapse.
On one occasion, we were breaking camp and only one leg would come up. Turned out that the shaft on the leg farthest from the motor had sheared off where it bolts to the cross shaft. Lucky for me, I carry a 1/2" drive cordless drill and was able to remove the cross shaft, hook the drill to what was left of the input shaft to the leg and raise it. Of course, I had to use my hydraulic jack to get the weight off the leg so the drill would have enough torque to lift it.
2004 Silverado LB7 D/A CC LB DRW 4x4, Firestone RideRites, Air Lift Compressor, Line-X Bed Liner, Retrax Bed Cover, Backup Cam, Pullrite Super 5th Hitch, Rear View Cam
AstroStart 2205A Remote Start
2014 Keystone Outback 5th Wheel
Trail-Air Pin Box
SpurHntr
Have a single motor setup
Motor goes through a lugged gearbox to drive the legs
The 4 lugs straddle the post
But twists markedly on actuation
Not sure to what degree is normal
Also
CANAMKID
I think they all twist a bit. Mine does also.
Steve
CanAmKid
Paul_G_
If you are referring to the motor, I believe they all flex, at least mine does. I don't know exactly why they do but I'm assuming it is a design factor. If you are not talking about the motor & shaft, then I'm not sure. I know this isn't much of an answer but nobody else seems to have made any comments.
Paul...
