Sportsman Pin Box Help
borninblue
I am about to purchase our first fifth wheel. I am new to towing and it has been frustrating dealing with the purchase. I am very cautious about getting my setup right before going on the road, so here is my problem:
We are looking at a 2014 KZ Sportsman S315BHK (new unit). I have a 2014 Ram 2500 with ramboxes. I need to have the sidewinder installed in order for towing to work due to the ramboxes. The problem is the dealer nor KZ can provide me with the model of the pin box so I cannot say for certain if the sidewinder will work. The dealer says the only thing on the pin box is the following:
S315BH
Plant#40
Norco Part#87004
S/N 0016797
After speaking with KZ they stated the pin box "should" be a Dexter because Norco only makes the frame. My question is then why is this sticker on the pin box with Norco's name on it? I looked at the pin box myself and do not see any other markings,but maybe the king pin is blocking it. There is a Mor/ryde king pin attached to the box currently.
The dealer states they would be able to make the sidewinder work with a "spacer" if it does not line up correctly on the box. I am new to towing so not sure about that. KZ says if it is not a direct fit and if modifications have to be made to make the sidewinder work it will void the warranty.....any help would be appreciated!
7 REPLIES 7
laknox
S315BH
Plant#40
Norco Part#87004
S/N 0016797
These numbers are for the frame, itself, not the pin box. MorRyde is the actual pin box, attached to the Norco frame; look for a label on that, instead. If no label, take pics and measurements and contact MorRyde. KZ does not show a MorRyde as an option on '15 models, so it was something factory-added in '13/14 or the dealer added it.
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
borninblue
Just got off the phone with Reese. They actually have a form where you can take pin box measurements and hole dimensions to determine if it will work. Great customer service, seems to be hard to find these days.
borninblue
Thanks, I understand they will not make suggestions, however they should know part numbers for the products they are selling. How would the dealer know what the pin box model is if it is not properly marked?
spadoctor
the sticker you see is the frame unit production label. Also factories often do not make suggestions as the are not and can not know each and every vehicle setup....that is where the dealer should come into play.
borninblue
Thank you for the replies! I will call Reese directly. I just don't understand how KZ cannot confirm the pinbox? As for the sidewinder would it be worth it to pay extra for the airride? They both function the same correct, with the airride providing more shock absorption?
newman_fulltime
and to throw another kink in it they also like using a demco venture kingpin on those
Reese 61302 is a universal fit part that would more than likely be the part you need
TomHaycraft
Consider giving Reese a call directly. I've got both a 16k Sidewinder (now pinned, no longer need pivot with 8' bed) and their R16 hitch. I've called them a couple times, always very helpful. Quite possible they can confirm the proper pinbox for your trailer.
2013 Silverado 3500HD - Duramax/Allison - CC, long bed, SRW, 2WD
2017 Grand Design Reflection 303RLS - TST 507 TPMS
