If they were in the stainless tapping screw section of the hardware store they are in all probability 18-8. They would only carry 410 in drill screws that had a drill point. If they were tapping screws you should be ok. I would also note that if reactive embrittlement occurs (on 400 series fasteners into aluminum) it Always happens within 24-48 hours per every expert I have read on the subject.
I would not recommend using a standard zinc plated steel screw in aluminum as the risk of the embrittlement is even greater. And corrosion will likely occur even if you cover with a sealant. Expansion and contraction of all the components will allow some moisture in the form of humidity to make its way into the joint.
Greg
You cannot stop growing old but you don't have to grow up. ๐
Chef/Pilot
DW/Navigator
2 Sons, 1 DIL, 3 Grandsons, 1 Granddaughter. Boz the cat:)
2012 F350 XLT 6.7 Powerstroke 4X4 SWD Crewcab.
2012 Wildcat 313RE-OK
