Tire Problems and What to Upgrade To?
Scott_M
Last fall we took a trip to North Carolina, mostly on interstate to visit family. After returning from the 1500 mile trip, I noticed that the rear wheels had come into contact with the plastic fender trim and had also bottomed out in the wells. We travel with empty gray and black water tanks, ยผ full fresh tank. We almost always have less than 1100# of payload (3305 max capacity).
Thinking I had a bad spring, I replaced all springs and shackles with a slightly higher capacity spring and wet bushings. While replacing a tire, I cut my hand of the tire I was trying to mount. I looked at the tire thinking there was a nail or piece of glass stuck in it, but found a small section of steel belt sticking out of the tread. I looked closer and found a bubble in the tread as well. These are the original tires (3 years old and about 6K miles), Power King Tow Max STRโ€™s (ST225/75R15, D Range). I knew that the tires were probably not the best, but I thought I should get at least 10K miles out of them. The GVWR on my fiver is 9950 with tandem 4400 axles and rims 15โ€ x 6โ€ (J).
Anyway, since I now have to replace the tires, I have been looking around the forums and internet. It seems like most people are opting for LT over ST tires. If I type in my tire size I get a lot of hits for the ST size, but very few for the LT size. Having read about a lot of D range tire failures I thought about upgrading to at least E range, but I have to check the rims for the maximum pressure/weight rating. I would hate to have to upgrade the rims as well, but I will if I have to. Anyone have any advice regarding the conversion from ST to LT? I cannot increase my tire size because the axles are already under the springs and I only have about 2โ€ on average of well clearance.
2021 Entegra Odyssey 24B Class C on Ford E-450 Chassis with 7.3L V8
20 REPLIES 20
laknox
Sounds like the belts let go in the center allowing your tires to balloon out. Had that happen on both my last 2 sets when they died, though no rubbing.
There are no E-range LTs in 15", so you're stuck with STs in that size if you want to go to an E tire. Of these, the Carlisle RH and the Maxxis 8008 seem to be the best bet. Not that they might not have problems, as any tire can, but they seem to have much, MUCH fewer problems. Of these 2, Maxxis would likely get the nod as a better tire. I currently have the Carlisles, but would have gotten the Maxxis had time permitted. Going into the 3rd year with the Carlisles and they still look good. Covered and on boards while in storage.
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
Dayle1
You are right to replace them, the tread belt is separating from the carcass and expanding. On my last trailer I had an identical problem with all 4 Maxxis load range E tires that were 3-1/2 yrs old. So, even the best ST tires are not that great. I also thought the problem was with the suspension initially, but realized it wasn't since the tire was expanding side-ways as well.
One more point, if you are towing nose high, then you have reduced clearance on the rear tires and contact over bumps and potholes could accelerate tire damage resulting in pre-mature failure.
Larry Day
Texas Baptist Men-Retiree Builders since '01
'13 Silverado 3500HD LT 2wd CCSB SRW, custom RKI bed
'19 Starcraft Telluride 292RLS
Rig Photos
Charlie_D_
After reading your post again I see that you only have 2" clearance in your wheel well. Have you bottomed out often? I can see where that would be a major problem.
Enjoying Your Freedom?
Thank A Veteran
Native Texan
2013 Prime Time Crusader 330MKS
2018 Chevy 2500 D/A Z71 4x4 Offroad
2006 Holiday Rambler Savoy 33SKT-40,000 trouble free miles-retired
2006 Chevy 2500 D/A-retired
2013 Chevy 2500 D/A-retired
therink
If your wheels are 15" I recommend upgrading to load range E tires. Your wheels will need to be able to handle 80 psi. Maxxis make a good ST load range E. I had them on on my last trailer and felt much more confident than the power kings load range D's I was running.
Steve Rinker
Rochester, NY
2013 Keystone Sydney 340FBH 5th Wheel, 12,280 lbs loaded (scale)
2015.5 GMC Sierra Denali 3500, SRW, Duramax, CC, Payload 3,700 (sticker- not scaled yet)
Take my posts for what they are, opinions based on my own experiences.
MFL
Nomad II
Nomad II
For the size/weight FW you have, the same size D rated tire should be more than ample. I would just replace with a better quality ST tire. Many like the Maxxis brand. A couple others are Carlisle or Provider. I have the Provider tires on mine, and like them. They are speed rated to 81 mph.
Jerry
Charlie_D_
No expert and often come here for advise but I don't believe you can use an LT tire of the same size because they don't have the same load capacity. You will probably have to go up in size. Give us the size of your current tires and others will be along to help.
Thank A Veteran
Native Texan
