Thanks for the post about the Style II. I full time since August 2010 and I'm on my 3rd Style II. The first two pooped (no pun intended) out the same way. The foot flush arm pivot hole wasn't round and the entire flush arm would wobble each time it flushed and eventually wouldn't control the flush valve properly. Thetford replaced the first one under warranty and Jayco replaced it the second time. Now I'm on my own and so far so good. The current one seems to be built better at the prior fail point so my fingers are crossed.
I have made the statement before, but I still feel this model isn't designed for full time use and just isn't up to the task. I do appreciate your comments on the repair, but I'm not sure I would do it. I'm thinking a brand new one for $200.00 would be a better deal for me. I know that flush pedal pivot isn't a durable design and I would hate to spend $75.00 and then still have a problem.
I agree that spring is a bear to work with. I guess I need to look at the video if I ever have to remove the arm.
Ed
KM4STL
2006 GMC 2500HD CCSB 4x4 Duramax/Allison, Titan 52 gallon fuel tank, Prodigy Controller, B&W Companion Hitch, Progressive Industries EMS-PT50C, TST Systems 507 TPMS
2010 Jayco Designer 35RLTS,Cummins/Onan RV QG 5500 EVAP
Fulltime since 2010
