Mar-18-2020 08:07 AM
Mar-18-2020 09:53 PM
dieseltruckdriver wrote:MFL wrote:
Well said 2014... and adding the turnover ball a waste, unless actually needed for a different goose neck trailer.
Jerry
I sat thinking my last post over for quite a while, and actually deleted what I am about to say.
As a former truck driver, if I bought a vehicle with an Anderson hitch, I wouldn't use it any farther than to get me home. No different than any sliding bar hitch.
Mar-18-2020 09:48 PM
dieseltruckdriver wrote:cummins2014 wrote:WTP-GC wrote:
This thread doesn’t need to go real far.
OP: get a B & W turnover ball, install in bed. Ignore the holes for the old rail system. There’s no benefit in trying to reuse them, plus you’ll eventually hate the rails. Then get a B & W Companion or Andersen Ultimate. You don’t need a slider. You don’t need to use the articulating feature of the TP pin box. Lock it out, check the fasteners from time to time. And pay attention when making tight maneuvers. The TP pin box is designed for those short bed half ton trucks. There is absolutely no good reason at all to use the TP articulating aspect on 3/4 and 1 ton short beds with newer fifth wheels. Don’t be distracted otherwise.
Oh!, come on , you'll eventually hate the rails, why. Had them for years ,and they were not an issue . I won't buy they get the road nonsense , sure they are there ,but pray tell what are they in the road of . What sliding in a sheet of plywood . Not hardly , you go in at an angle anyway ,and after the first sheet thats a done deal.
Granted if he had the puck system great, but apparently he doesn't so now you want him to blow another large hole in the bed :h . He already has the holes use them , with bedrails ,and a good hitch he is set ,and a strong four point attachment . No fan at all of gooseneck ball attached hitches , all the torquing ,and one point of attachment . Forget the Ultimate ,and go with the steel rail mount Andersen as said .
I have to disagree with you. My last pickup had rails and a sliding bar hitch (not a slider hitch). I went with the B&W turnover and Companion on this pickup and couldn't be happier. I HATED those rails every time I used my pickup as a pickup. I could never sweep out the bed, or shovel things out. Those are some things no one ever talk about when hitches are discussed.
Mar-18-2020 07:21 PM
Jerry
Mar-18-2020 07:16 PM
Mar-18-2020 06:39 PM
Mar-18-2020 06:32 PM
Mar-18-2020 06:05 PM
Mar-18-2020 04:06 PM
Mar-18-2020 10:25 AM
RooDude09 wrote:
I definitely want the extra clearance all the time so that if I need to make a tight turn) I don’t forget to look if the trailer is going to hit the truck.
Mar-18-2020 09:20 AM
Mar-18-2020 09:11 AM
Mar-18-2020 08:59 AM
RooDude09 wrote:
My wife and I are looking to switch to a fifth wheel from a bumper pull. I have a 2015 F-250 with short bed. The trailer we are looking at is equipped with a turning point pin box. I’ve seen and read some things on the internet that make me question the stability of system when towing and the blocking mechanism to keep the pin from turning in the hitch. I know my other option is to put in a sliding hitch and I’d be most comfortable with an automatic slider but that drives the price up substantially. My truck was previously outfitted with a rail system of some sort but everything is gone but the holes are in the bed. I’ve priced out the factory ford prep kit but it looks like puck style hitches are more expensive although I have the means to put it in myself as I’m a mechanic at a ford dealer. If anyone could give me they’re advice on what you like/use it would be greatly appreciated.
Mar-18-2020 08:51 AM
Mar-18-2020 08:28 AM
