Dec-12-2015 12:42 PM
Dec-12-2015 04:26 PM
b727capt wrote:
I too am interested in this combo. Looking at ordering a new Weekend Warrior and they may put 17.5's on at the factory. GRWR is 21k with standard 8k axles. I also am considering upgrading to hydraulic brakes. What 17.5 tires are the best?
Cummins12V98 wrote:Jimf1234 wrote:
The other issue is that I'm sure my wheels are only 80psi so it doesn't do much good to run g's at 80psi.
85psi is the minimum for the GY "G" tire. If your rig came with E's 85 is most likely the proper pressure for your rig. I went from GY "E" to GY "G" on my Avion with 80psi rims and ran 85psi with the G tires and had perfect wear with thousands of miles.
Dec-12-2015 04:22 PM
But do you need 4800# capacity per tire at `125# ?
That's 19,200# of capacity.....
6K axles-------Approx. 11,500# or less weight on axles
I agree 17.5 wheels appear to be over kill.
I have 16", G rated,110 PSI Sailun's on my OEM rims
Dec-12-2015 01:41 PM
Dec-12-2015 01:39 PM
Dec-12-2015 01:37 PM
Dec-12-2015 01:16 PM
Dec-12-2015 01:09 PM
Dec-12-2015 12:54 PM
Dec-12-2015 12:52 PM
