voltage 3800 problems
Sajcmebdz9
Did any one else have the problem of bad quality of there Voltage toy hauler.
We got ours and it looks 10 years old.
Just no care in workmanship
Just alot wrong and feeling like I got cheated
20 REPLIES 20
Rockerrider
Yamahauler1 wrote:
Mine was PDI'd for 3 days.
3 days??? So you spent 24-30 hours at the dealer doing PDI? Uh huh...not likely.
Where did the OP go? Comes on here to bash Voltage then disappears.
Brought mine home from it's winter nap last night....been in storage since October. Generator fired up in about 3 seconds...furnance fired right up...fridge fired right up...all slides work great. Can't wait for it to warm up enough to use it again!!
Yamahauler1
Mine was PDI'd for 3 days. Took it home and them used it for 3 months. Back it went to the dealer for a LONG list of warranty. 6 monthe later, back again. The following spring, both slides were coming apart, so it was taken 1,000 south to Pendleton to get fixed at a factory.( and yes, it is level with all 6 jacks down everytime). They look "flashy" on the outside, but remove some inside covers, some air outlet vents, etc, and see what's behind. YOU WILL BE SHOCKED!Itis only a matter of time when the Schwintek slides jam up in the wall because the screw heads that hold the tracks to the slide sides rust and keep popping off, the cheap roller that support the bottom of the slides break because they are made of garbage material,and on and on. The problems are still endless with mine and only 2 years old. Private message me if you like, as I have tried posting photos on here, but no luck.
Lyrikz
Why did you buy a trailer that looked 10 years old.
These posts are nuts sometimes.
I was just getting ready to purchase a 3800. They look amazing. Flat glass. Real paint.
They were built very well in my opinion. I couldnt get over the wood under the slideouts...
Td119
I am looking into purchasing a Voltage 3800 and would be very interested in hearing about the issues you are having with the 3800. Can you give us more details?
Macman83
I did a 3 1/2 hour PDI and then had them fix everything on my list before I wrote the check. Ours looked good, and we have had it back to the dealer once for a water leak. Our dealer here is very good, and we had had few issues with our 3905.
2010 Ford F450 Superduty diesel
2013 Voltage 3905
Rockerrider
Nope...Love ours!! Few minor issues when it was new. Everything fixed prior to delivery. Of course I did a very detailed PDI.
How long have you had this trailer? Did you not look at it before taking delivery?
