voltage
boingram
....arguing w a neighbor. ...is the voltage coming out of a shore power pole in a cg 110 or 220...
20 REPLIES 20
bpounds
Timay wrote:
When I first wired my 30 amp outlet to hook my trailer to shore power, I plugged the trailer in and blew ALL my electrical items...seems I wired the outlet for 220 instead of 120!
Oh - did I mention that I am a master electrician? ๐Ÿ˜ฎ I booted my own butt around the entire back yard!
Tim
Yeah, I wouldn't feel too bad about that. Nothing else in our world uses a big plug like an RV plug, and is only 120V. We see that plug and 240V instinctively pops into our mind. It is a common mistake for experienced electricians, when their experience doesn't include RV's. Of course, verifying voltage and load should come first, but yeah, things happen.
2006 F250 Diesel
2011 Keystone Cougar 278RKSWE Fiver
John___Angela
Tim
๐Ÿ™‚ Stuff happens...and then you move on. ๐Ÿ™‚
2003 Revolution 40C Class A. Electric smart car as a Toad on a smart car trailer
Life is not measured by the number of breaths we take but rather by the moments that take our breath away.
Timay
Tim
John___Angela
Too funny. Ran into a neighbour camper house builder electrician guy in a provincial park probably 10 or 12 years ago. He was quite adamant about the voltage at his 30 amp connection was 220 volts (plus or minus) and that all campgrounds were like this. I told him i would bet him all the cash he had on him that it was 110 (plus or minus). Made a little pocket change that day. ๐Ÿ™‚
Coach-man
First of all, Most, 99%, of the RV's are 120 volt, period, end of sentance! This is regardless of amperage, i.e. 20, 30, or 50 amp! 20, or 30 amp consists of a single hot 120 volt hot lead, a single neutralleg, and a ground leg. A so called 50 amp service consists of two 120 volt hot legs, each capable of handeling 50 amps, a common neutral leg, and a ground leg, 4 wires. This is identical to an electric dryer circuit, which draws 240 volts @ 50 amps. The differance with an RV is you do not use the 240 volts, you use two 50 amp 120 volt circuits.typically wired so one AC and the hot water heater and some 120 volt circuits wired to onE leg, the second AC, furnace, microwave, and the rest of the 120 circuits wired to the other. So while the pedestal is wired identicle, if you plug your dryer into it it is 240 volts, if you plug your RV into it, it is 120 volts!! Unless you are inanindustrial area, you have 240 volt service, in an industrial area you could have 3 phase 208 volts, which is a differant ball game.
Me_Again
Allworth wrote:
For nubies, the best description of RV 50Amp service is:
2 circuits, each 120volt; 50Amp. Combined in one service cable.
Loose neutral and see what the RV sees!!!! Chris
boingram
...he did. ..but he builds houses...was an electrician. ...but i learned a lot!
Old-Biscuit
So who won???
You didn't clarify which one of you thought 110V :B
Water-Bug
2oldman wrote:
Bottom line, it's whatever the voltmeter says it is.
Or, it all depends upon which pins of the connector the voltmeter is connected to. The real answer is that the pedistal supplies 220VAC but most RVs are wired for 110VAC service only. A 220VAC 50 amp appliance could be plugged directly into the pedistal and it would work properly.
2oldman
RustyJC
The 240VAC between L1 and L2 is important, though, since a power management system determines the presence of 50 amp service based on 240VAC being present between L1 and L2. If these legs are in phase, the power management system will see 0VAC between L1 and L2 and will default to 30 amp service.
Rusty
2014.5 DRV Mobile Suites 38RSSA #6972
2016 Ram 3500 Dually Longhorn Crew Cab Long Bed, 4x4, 385/900 Cummins, Aisin AS69RC, 4.10, 39K+ GCWR, 30K+ trailer tow rating, 14K GVWR
B&W RVK3600
Allworth
Formerly posting as "littleblackdog"
Martha, Allen, & Blackjack
2006 Chevy 3500 D/A LB SRW, RVND 7710
Previously: 2008 Titanium 30E35SA. Currently no trailer due to age & mobility problems. Very sad!
"Real Jeeps have round headlights"
RoyB
Here is a quickie diagram of a campground pedestal
50AMP SERVICE
30/20/15AMP Service
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
2oldman
So much knowledge at our fingertips.
