washing machine
DianeC_
Hi everyone, I hope someone can help. I have a 06 Pilgrim Open Road it has 4 slides, 41 ft (I think). It has an all-in-one vented washing machine up in the closet of the master bedroom. I cannot find the turn on valve to supply water up to the machine.
Can anyone tell me where it might be?
TIA, Diane
10 REPLIES 10
RustyJC
MPI_Mallard wrote:
RustyJC wrote:
Our 5th wheel has a master water manifold with valves to each of the branch services. Most, however, don't - our Jayco Designer XL 3610RLTS didn't. It only had the hot and cold water valves in the washer/dryer closet.
Rusty
Our fiver has a manifold system that has shut-offs for the hot/cold to the washer/dryer, there are shut-offs for all the plumbing sources in our CC Daydreamer, **** good thinking on their part!
Sheryl Crow: "Its not having what you want,Its wanting what you got"
That's great! I'm glad yours has a valved manifold - all of them should (IMHO), but most of them don't.
Rusty
2014.5 DRV Mobile Suites 38RSSA #6972
2016 Ram 3500 Dually Longhorn Crew Cab Long Bed, 4x4, 385/900 Cummins, Aisin AS69RC, 4.10, 39K+ GCWR, 30K+ trailer tow rating, 14K GVWR
B&W RVK3600
MPI_Mallard
Rusty
07' Dodge 3500 6 speed Cummins Diesel Dually/6.7L Bully-Chipped /
Exhst Brake/07' Cedar Creek 37CDTSD Daydreamer fiver
Mallard @ Frau Blรผcher
Red Green:
Now lets Bow your heads for the men's prayer.
I am a man, but I can change.
If I have to, I guess...
DianeC_
Thanks everyone I will be searching next weekend, preparing to open for the season.
Racine96
I suggest to look in the basement. There might be some there.
enblethen
The wet bay is the outside compartment where the fresh and waste water valves are.
Left side toward from of rear slide.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
RustyJC
Rusty
B&W RVK3600
Itching2go
BB_TX wrote:
Don't know why there would be any other valves. I am fairly certain there are no valves to mine except the ones behind the washer.
Same here. The only valves that we have are those behind the washer/drier.
2008 Jayco Designer 35RLSA pulled by a 2007 Chevy 3500 D/A SRW
BB_TX
DianeC_
Thanks Ken, the valves that are located in the closet are visible, the hoses are attached to the washer. I can't locate the valve that brings the water to those valves.
TXiceman
The hot and cold water valves are usually mounted behind the washer/drier unit. Reach over the top and see if you can feel them or use a flash light and a mirror.
Ken
Amateur Radio Operator.
2023 Cougar 22MLS, toted with a 2022, F150, 3.5L EcoBoost, Crewcab, Max Tow, FORMER Full Time RVer. Travel with a standard schnauzer and a Timneh African Gray parrot
