Feb-11-2017 03:52 PM
Feb-17-2017 01:58 PM
Feb-17-2017 01:31 PM
Feb-13-2017 11:17 AM
Feb-13-2017 08:05 AM
Feb-13-2017 05:51 AM
beazleybub wrote:
What part of the wall is the top plate attached to? Hopefully the inside frame. I assume it will be due to the original skin being 1/8" or 1/4".
Feb-12-2017 04:18 PM
DownTheAvenue wrote:
If you Filon sides, like you claim, you are dealing with delamination. Your unit is not stick built. The walls are vacuum glued and the whole wall is one integral unit. You MAY have studs in the walls, but it is not built like you are envisioning. Now, if you don't have Filon, but aluminium siding, then stick built may be a more appropriate term. Good luck to you.
Feb-12-2017 04:09 PM
Dayle1 wrote:
The wall will have a top plate and each roof truss will be attached to it. You have to remove the rubber roof and plywood roof decking if any truss needs to be replaced or repaired. Wiring and A/C duct will run thru the trusses, so repairing will be much easier than replacement.
Feb-12-2017 03:56 PM
beazleybub wrote:
Still, my question remains unanswered though. I'm trying to determine how the roof trusses are mated to the camper. I'd like to leave the roof repairs for dead last if possible. Do I have to repair the roof first or can I repair the walls and siding first? Common sense tells me to fix the walls and siding first, so I may have answered my own question. 😄
Feb-12-2017 03:50 PM
Feb-12-2017 01:58 PM
beazleybub wrote:
I'm sorry but, you are mistaken. My rig is stick built, 2" studs, 16" on center.
With that said, I have decided to break the mold and use an alternative method to re-side my rig. I know weight is an issue, so after much research, I have decided to use "LP SmartSide 38" panels. These panels do not require a backer and can be nailed or screwed directly to the studs themselves. The (0.315-in x 48.563-in x 95.875-in) panels only weigh 41 pounds each, which makes them lighter than the plywood they will be replacing. The panels are not expensive, at $26 each I can completely re-side my entire unit for under $600. The only issue installing them will be with the nose of the trailer. The panels cannot be bent, so I will have to either use a different siding for the nose radius, or reconstruct the nose to a flat profile.
Feb-12-2017 12:24 PM
Feb-12-2017 12:10 PM
beazleybub wrote:
Found some new information. Dayle1 can you give me your source for what you said the filon weighs with luan backing?Dayle1 wrote:
Actually, the "plywood" used is either a single layer or two layers of 1/8 in lauan plywood. A 4x8 ft section will weight about 22 lbs if two layers are used, so it is lighter than the panels you are considering
I found some information from Crane Composits website (The people who make filon.) that suggests filon with luan backing weighs anywhere from 0.95lb/ft² to 1.15lb/ft² depending on which type you choose. (They make different thicknesses.) The lightest they manufacture is 0.95lb/ft² and a 4X8 sheet would weigh around 30.4 pounds. That's only 10.6 more pounds a sheet. So if the factory finished side of my camper weighs 267 pounds and my new side weighs 198 pounds, my new siding would only be 69 pounds heavier. By switching to LP SmartSide panel my rig will gain less than 200 pounds.
I don't see enough weight difference to cause an issue.
Feb-12-2017 12:03 PM
beazleybub wrote:
Not to sound argumentative but, why then are hundreds of people in the tiny house community using LP SmartSide panels? The panel I chose is structural and suited for 16" on center framing.
Even houses "flex" on a daily basis. With proper installation and sealing, I do not believe it will be an issue. I will be also wrapping my rig with tyvec wrap. This will greatly reduce any chance of future water damage.
Feb-12-2017 11:48 AM
