โJul-01-2015 10:25 AM
โJul-21-2015 06:35 PM
โJul-21-2015 06:03 PM
โJul-03-2015 11:10 AM
โJul-03-2015 11:05 AM
โJul-03-2015 10:54 AM
Thumb wrote:Old-Biscuit wrote:Thumb wrote:
Sounds to me as though the new pump
is discharging more flow than the old pump
Cavitation results when a pump can discharge excessive volume that exceeds the
suction water supply and causes a drop in the required suction inlet pressure
Assuming you don't have other suction side leaks or pressure issues, this will help you
Install a shutoff valve on the discharge of your pump
and with the pump running and the shower turned on
slowly close the valve until the cavitation stops
Cavitation is caused by loss of suction head.....
Having the pump at too high of a distance above the fluid source
Having too small of a diameter of suction pipe
Having too long of a distance of suction pipe
Having too many fittings on the suction pipe
Handling a liquid with a low vapor pressure
Running the pump too fast
Most likely NOT an issue with OPs RV water pump.
The Surflo 4008 pump is a diaphragm pump and the diaphragm only moves 1/8"
OP states pump works properly on other faucets/toilet but has problem when shower is used.
Low flow/low demand....pump hitting pressure set point causing rapid cycling of pump.
I agree and All true except for the pump running too fast statement
The pump speed and the specific impeller design are matched by design
I spent many years doing that type of water systems product design and training
Loss of required head (pressure) at impeller , also known as Net Positive Suction Head
NPSHR, causes cavitation
Cavitation is characterized by the noise made by the imploding air bubbles that formed on the vanes of the impeller because of loss of required NPSH
But all of this is a mute point since learning that the pump is diaphram type
and no impeller used
I have eliminated what sounds like the same issue in a Cougar we used to own by doing as I suggested in my post but that pump had an impeller
Good luck with your issue, hope you get it fixed and back to camping in peace again
Happy 4th to all!!!
God bless America!!
โJul-03-2015 10:49 AM
โJul-02-2015 06:08 PM
โJul-01-2015 03:23 PM
โJul-01-2015 03:12 PM
โJul-01-2015 02:18 PM
โJul-01-2015 02:02 PM
โJul-01-2015 01:46 PM
โJul-01-2015 01:08 PM
โJul-01-2015 12:36 PM
