Sep-20-2020 06:58 AM
Sep-20-2020 08:21 AM
BarneyS wrote:
I agree that the flow rate seems very low. I don't think I would use it but would get one like the one you already have.
Barney
Sep-20-2020 07:49 AM
Sep-20-2020 07:34 AM
agesilaus wrote:
The rated flow is 1.8 gpm vs the 3 gpm of the Sureflow pump that I have. So water flow will be low, you might have a problem with your shower flow. That sureflow is a diaphram pump too but it has a built in bypass. That pump you have seems to be designed as a sprayer pump, notice that it is not in the automotive area of amazon where the RV equipment is found.
It may work try piping it up outside the RV to the regulator and see if it works. If you are on city water do you even need a water pump?
Sep-20-2020 07:31 AM
corvettekent wrote:
Does your old water pump still run but does not pump water? If so it's an easy fix with ***Link Removed*** new pump head.
Sep-20-2020 07:30 AM
Sep-20-2020 07:28 AM
Sep-20-2020 07:12 AM
agesilaus wrote:
What is the amperage draw on that 160 psi pump and is it 12V. And can that diaphragm pump deal with a cut off head, meaning it is pumping against a closed valve. Positive displacement pumps can have problems in that case.
Sep-20-2020 07:09 AM
