โApr-25-2019 12:36 PM
โMay-02-2019 08:42 PM
โMay-02-2019 05:50 PM
โMay-01-2019 06:54 PM
โApr-30-2019 07:10 AM
โApr-29-2019 05:46 PM
maddog348 wrote:
how did he determine the tank was actually full. That was my question. did the water run out the over fill??
โApr-29-2019 04:45 PM
โApr-29-2019 01:23 PM
maddog348 wrote:
40 gallons to absolute 'running over' full OR Full when the gauge light turns green. We can actually see the water in the tank ~bi-level~ holds quite a bit after the light goes on.
JM2ยข ~~ YMMV
โApr-29-2019 01:11 PM
โApr-29-2019 11:11 AM
โApr-29-2019 09:22 AM
Rwake901 wrote:How long do you expect to go with the on board water system?
So you think 10 gallons per person per day is too much?
โApr-29-2019 08:52 AM
Rwake901 wrote:
So how did this go from the manufacturer misrepresentation of the size of their fresh water tank to I use too much water?? The amount of water we use is irrelevant here. This is about being lied to by the manufacturer not how much water we use.
โApr-29-2019 07:10 AM
โApr-29-2019 06:40 AM
B.O. Plenty wrote:time2roll wrote:Thank you. Good to see others have the same idea.bpounds wrote:That is the point. If 40 gallons gets the OP two days then the 60 gallon spec only goes three days.B.O. Plenty wrote:You obviously don't boondock much.
Another 20 gals. would only extend your camping by one day...
Need more conservation.
B.O.
โApr-27-2019 10:35 AM
