When Tires are Changed on a 5th Wheel
MSFSnTEXAS
This is my first time to own a 5th wheel. Lots of questions still. But the immediate question I have is about the tires being changed tomorrow.
Again, I know I'm going to sound like a total fool, but will the 5th wheel remain hitched to the truck when they jack up the 5th wheel to remove the tires? Or do I unhitch from the truck and lower the jacks (front only, rear and front)? Seems to me that if I unhitched and lowered jacks that when they jack up the 5th wheel that it would have a negative impact to the jacks.
16 REPLIES 16
rhagfo
Leave it connected, likely the tire shop will place their jack directly under the spring pad and lift just enough to get the tires clear of the ground. They may use two jacks one on each axle and do the whole side at the same time. have them balanced at the same time. What type and size?
Peg_Leg
Leave it hitched. They will jack under the spring shackles for each tire.
2012 Chevy 3500HD Dually 4X4
Crew Cab long bed 6.0 gasser 4.10
2019 Open Range OF337RLS
Yamaha EF3000iSE
retired gadgetman
