Furnace usage
mchero
Out here in Quartzsite AZ and had to fire up the furnace for the 1st time. I want to install an extend-a-stay type connection so I can use a larger tank but DON'T want to use the furnaces due to them being horribly inefficient both on propane and 12VDC.
What heater have you other full-time RV'ers been using and are you satisfied? Next door neighbor suggested a "Blue Flame" but I guess I'll do some googling tonight.
Thanks
Robert McHenry
Currently, Henniker NH
07 Fleetwood Discovery 39V
1K Solar dieselrvowners.com
2005 Jeep Grand Cherokee
Prior:1993 Pace Arrow 37' Diesel
31 REPLIES 31
JiminDenver
There are modern versions of a gravity furnace like used in my folks trailer. Very quiet due to no fan but slower to heat the space and likely less efficient because of it too.
2011 GulfStream Amerilite 25BH
2003 Ford Expedition with 435w tilting portable/ TS-MPPT-45
750w solar , TS-MPPT-60 on the trailer
675 Ah bank, Trip-lite 1250fc inverter
Sportsman 2200w inverter generator
time2roll
ro_sie wrote:
2oldman, all I can tell you, as I wasn't there, is that is what was said at the time. They said the room they were sleeping in was closed up as air tight as they could get it, and they all died. It was mid Missouri in the coldest of winter and for some reason or other they had lost their heat source. All I know is, I am very careful with space heaters. Take it as you please. I just know I lost someone who was a very dear school friend.
No Oxygen depletion or Carbon Monoxide is created by electric heater or heat pump.
mchero
Will DEFINITELY keep a window cracked as well as a roof vent. As you all know these rigs are not air tight. We have a full wall slide as well as propane leak detector as well as a smoke detector AND a carbon monoxide detector that are tested on a regular basis. Also the ventless propane heaters sold these days MUST have oxygen depletion sensors.
Robert McHenry
EsoxLucius
It likely could not have been an electric space heater, unless it started a fire. It was most likely a portable propane heater for which there are many cases of CO fatalities every year.
2013 LTV Unity MB Theater Seats
635 watts solar panels, 440 AH batteries, BlueSky Solar Boost 3024iL & IPN-Pro Remote, Magnum MS2000 & ME-RC50 remote
Koni Shocks F & R, Hellwig 7254, SumoSprings F & R
2012 Hyundai Accent SE, Blue Ox Aladdin/Patriot
ro_sie
ro_sie
Art ( my roomie)
Fleetwood Revolution LE
2oldman
ro_sie wrote:
... she and her husband and two children were using a portable electric heater for heat. Apparently all the oxygen in the room was used up...
I didn't know electric heaters used oxygen.
ro_sie
I know what I have to tell you is not about an RV. But years ago I lost an old high school friend because she and her husband and two children were using a portable electric heater for heat. Apparently all the oxygen in the room was used up while they were sleeping and the 4 of them died. So, if this is what you are doing, please crack a window near that heater. I don't want to read about any of you or see about you on the television news.
ro_sie
Art ( my roomie)
mchero
EsoxLucius wrote:
If possible you could replace your furnaces with efficient and quiet Propex HS2800 furnaces.
http://www.propexheatsource.com/heaters/hs2800-furnace/
Sure I have 700 to 800 to drop for one of those.....NOT But a good suggestion, Thanks!
Robert McHenry
mchero
EsoxLucius wrote:
mchero wrote:
Looking at this model;
http://www.landmsupply.com/department/home-improvement/heating-and-cooling/propane-heaters/ventless-...
What's your thoughts?
RM
Note what the manufacturer says:
Not for use in bathrooms, bedrooms, or recreational vehicles. 4,500ft high altitude restriction. Propane cylinder must remain outdoors.
Thanks for your concern EsoxLucius, I did see that thanks.
Robert McHenry
EsoxLucius
EsoxLucius
I would recommend a vented catalytic propane heater. No CO or CO2, or moisture problems.
http://ventedcatheater.com/6.html
EsoxLucius
RM
paddykernahan
We used a Olympian propane heater for the last 25 years in our pop-up.
Dead silent and no electricity needed.
Needs ventilation because of oxygen usage and humidity control.
Pop-ups already have lot of ventilation.
Haven't tried in our new class C yet.
Sure you would need to let some of the moisture escape.
Wonder how much more efficient the ventless propane heater would be since you would have to have some windows open. 12 VDC conservation would be king with these heaters.
mchero
2gypsies wrote:
We used the Empire propane heater for 16 full-timing years with lots of boondocking (Quartzsite, too) - and even if we were plugged into electric at a RV park.
The RV furnace is inefficient, noisy and cycles on and off with heat and cold.
The propane heaters give a constant warm heat. They are awesome!
They are used by many, many full-timers.
Thankyou 2gypsies!!!!
Found this interesting article.
http://roadslesstraveled.us/rv-heater/
Also note how regulated such heaters are. They now MUST have automatic low oxygen shutoffs. We all know how air tight these RV's with slides are.....NOT!! LOL
RM
Robert McHenry
