Rid-X
bendjoseph
Has anyone tried Rid-X in their black tank?
Ben & Melissa
1 Spoiled Golden
33 Foot Prowler, 2004
27 REPLIES 27
wildwest450
It's snake oil in a home septic or any where else. Maybe put some in a glass and make some sea monkeys. Funny how people are so easily fooled into buying stuff that's not needed.
Roy_Lynne
I would be afraid of its reaction to the plastic in the holding tank and would absolutely not use it. I
BarbaraOK
Undoubtedly sitting for a week with water caused things to break down. WATER, WATER, WATER, that's all you need.
We're into our 8th year of fulltiming. All we ever do is use water and don't dump until it is 2/3 full or more. People don't use enough water, that is the trick.
But if it makes you feel good to spend money on nothing, go for it. Me, I'd rather spend the money on some wine and help out the black tank that way!
Barb
Barb & Dave O'Keeffe - full-timing since 2006
Figment II
(2002 Alpine 36 MDDS) ๐Ÿ™‚
2018 Ford C-Max HYBRID
[purple]FMCA - F337834, SKP #90761[/purple]
Our Blog
Bumpyroad
brirene wrote:
I used it once after camping with bil and his family. Of course his kids used our bathroom several times, and when I went to dump it was clogged. Put a fairly small amount of Rid x in the tank,.dumped the next weekend as smoothly as,...well...you get the idea.
sitting for a week giving solids time to break up probably did as much good as the ridx.
bumpy
paulcardoza
Rid-X won't hurt anything but your wallet. BUT, it won't help anything either. It's beneficial for use in septic tanks, not RV holding tanks.
If you don't mind paying for it and it makes you feel better, use it.
Paul & Sandra
Plymouth, MA
2014 Heartland Cyclone 4100 King
daily_double
I use a packet of regular baking yeast once a month in my septic at home. I guess a small amount will do the same in the black tank.
brirene
Jayco Designer 30 RKS Medallion pkg, Trail Air pin
'05 F350 6.0 PSD CC 4x4 DRW LB B&W Companion, Edge Insight
โ€œCertainly, travel is more than the seeing of sights; it is a change that goes on, deep and permanent, in the ideas of living." Miriam Beard
Big_Katuna
Waste of money. In your RV or your house.
My Kharma ran over my Dogma.
Bumpyroad
hey, if it makes you feel all warm and fuzzy, go for it.
bumpy
bendjoseph
I will give it a try. Our RV is hooked to a septic tank that we share with another seasonal. They use very little water in their black tank. I was hoping that the rid-x would help with cleaning my tank, plus work on all the "solids" my neibghors send out. As for price, it's $6.97 for a box that treats 1500 gallons. That's $.21 a tank.
Ben & Melissa
1 Spoiled Golden
soren
Been a topic of conversation since the beginning of self-contained RVs. It is not a good idea, but a harmless waste of money. The fact is that you have a HOLDING tank under the RV toilet, not a septic system. The goal is to keep the contents of the tank well liquefied to allow for easy and complete discharge, and to control the odors, that's it. If you allow the contents of the tank to remain long enough, they will begin the process of anaerobic decomposition, just as they would in a simple septic system. That said, this process is not necessary, or intended when using the holding tank.
Remember, these type of products are marketed by companies that need you to believe that they are necessary. They are not necessary in a properly functioning residential septic system, and they are just a waste of money in a camper.
gatorcq
Why would to use it? It is a plastic tank and not a septic system.
Once a month, preform a 15 to 30 minute flush.
Use a cheap water softener, pour about a 2 to 6 ozs.
Once every 2 years have it power flushed.
Save yourself the cost of chemicals
Dale & Susan
DaGirls II Rv - Dakota & Tilly Traveling Companions.
2008 Alfa Gold, 2015 Ford F150 XLT
Roadmaster and Air Brake System
1600 Watts, Magnum Inv/Chg&Solar
800 Lithium Battery
DaGirslRV Blog
thecampingman
Nope, but it sounds like a good idea.
Rid-X website
'03 GMC 4500 Topkick with Duramax/Allison
'04 36' McKenzie Medallion triple slide
Cabover kayak racks w/18' touring kayaks.
Bicycle carrier on the front with a street bike & a mountain bike
Snowbird W/Ohio camper dock
