Jul-13-2022 08:12 AM
Jul-19-2022 07:14 AM
Jul-16-2022 10:08 AM
LouLawrence wrote:
If you cannot run a new cable via the same route you can take a different one. Maybe you need to run the cable to the base of the antenna and then across the roof to a more accessible entry location. Depending upon where the booster is located, look around and see if you can locate easy access to the roof and you have found the path for the new coax. Don't be concerned about problems with a coax laying on the roof. You just secure that to the roof and it will be good for many, many years to come.
Jul-16-2022 05:36 AM
Jul-16-2022 04:47 AM
Jul-16-2022 04:29 AM
Jul-15-2022 04:17 PM
Jul-15-2022 03:06 PM
Jul-15-2022 01:13 PM
kevphillsaxplayer wrote:ford truck guy wrote:
As far as the numbers on each, I do not know... IF you wanna see where they run, you can always buy one of these -
***Link Removed***
race and label them yourself
Ok. Took your advice and purchased the meter. The cable marked number two goes back to the back bedroom, the front of the box is the line out for the front television. The cable marked 0 is for the cable hook up so that leaves line one which has to be the antenna but I’m getting a fault on that circuit. I don’t know where that goes through my wall. I’m thinking I might have to snake a line up through there and do a reconnection. Any advice?
kp
Jul-15-2022 12:46 PM
***Link Removed***
Jul-13-2022 11:20 AM
Jul-13-2022 11:15 AM
***Link Removed***
Ok. That’s a pretty cool device. If I’m understand it I plug the tool into the line in question and put one of the color coded remotes on the other end and if it lights up that color I have a match?
kp
Jul-13-2022 10:53 AM
***Link Removed***
Jul-13-2022 10:44 AM
MountainAir05 wrote:
One is going to be the Antenna, The other one could be a Cable/sat line if you have sat. The other one the TV.
Power on the box and try each cable to the TV.
Or you can jump out the one line at the cable back in the electric door and ohm it out inside the RV. That will give you one.
As stated one is TV antenna, but knowing which the other two does not take too much time to figure it out.
Jul-13-2022 09:31 AM
