Feb-19-2015 07:31 AM
Feb-21-2015 03:28 PM
Feb-21-2015 07:11 AM
Feb-20-2015 12:12 PM
Feb-20-2015 10:51 AM
Feb-20-2015 08:13 AM
Feb-19-2015 09:05 AM
dieharder wrote:
Check the wire connecting the converter to the batteries. I had the same problem with mine and there was part of the wire that had worn off the plastic coating and was sometimes making contact with metal around it. I realized that it wasn't a total power issue when I saw the microwave digital display still blinking despite no lights, etc.
Feb-19-2015 09:04 AM
Feb-19-2015 08:53 AM
Feb-19-2015 08:17 AM
Feb-19-2015 08:11 AM
mikeyp wrote:
Have a spooky new problem - my Fleetwood Bounder is plugged in here at the campground for the month. The 110v current is solid and house batteries fine and pretty new. About on average once a day, totally intermittently and with the regular 12v stuff running (frig, hot-water controller and 1-2 lights) when we switch on a new light (12v) the entire 12v system stops. Everything goes dark. Except the 110 v (TV, computer, etc) lines. They stay lit. So its not the shore line. The converter seems to keep humming though I have not been quick enough get outside around back and to check it. The outage last varyingly 5-30 seconds. Then for no reason - everything comes on, fine and all systems go. No brown-in - just instant spontaneous start. Anyone have any ideas? I did buy a back-up converter with the expectation of needing it to swap in - but don't want to if this is coming from something else. PS - it always happens exactly when we turn on a 12v lamp - different ones each time. Thanks. Mike P.
Feb-19-2015 07:58 AM
Feb-19-2015 07:40 AM
