1992 itasca sunrise 454 operating temp
Itasca55
Ok this was first trip I took in super hot conditions . I was watching all gauges . Temp gauge ran from about 180f to brief times going up hill
passing to 210f it never went passed 210f . It has a 15 lb cap on radiator . I did not use front air conditioner at all while driving as it needs a recharge. Is this normal temp for the 454 ? To me its a strong running 454 for 12,300 lbs when you call for 454 gods you get some serious thunder action ๐Ÿ™‚ temp outside ran from 93f to 85f about 80% humidity. My average speed 60mph to 70mph . coach air conditioner ran 4 days straight when parked so that's working great ๐Ÿ™‚ any info be great .
Itasca55
7 REPLIES 7
magik235
That is a normal temperature range. No problems.
cj7365
Normal
jplante4
Also take into consideration that factory gauges are not that accurate. What you're looking for is the normal range, regardless of temps. Anything above normal is an issue.
Jerry & Jeanne
1996 Safari Sahara 3530 - 'White Tiger'
CAT 3126/Allison 6 speed/Magnum Chassis
2014 Equinox AWD / Blue Ox
Camreal
Mine ran about the same or a little higher and thats probably why it was hard on exhaust manifolds. Had to replace them couple times. Strong engine.
Gjac
What temp thermostat do you have? If 195 F that is very normal. If 180 F it should be lower. Also if you are using the dash gauge it may be off. When I replaced my sensor for the gauge I noticed a 15 degree difference between the old and new.
mike_brez
My 94 PaceArrow with a 454 ran 205-210. I'd say it's normal.
1998 36 foot Country Coach Magna #5499 Single slide
Gillig chassis with a series 40
02 Ford F250 7.3 with a few mods
2015 Wrangler JKU
the_vfox
Sounds like a normal temp range. My 93 Kountry Star was about the same.
Fox and Angel, fuzz ball cat and crazy Yorkie :S
Don't call me on the weekend, Im out camping.:C
2001 Itasca Horizon DP 36LD 330 Cat and all the bells and whistles
Go Blue, US Air Force(retired)25 years ๐Ÿ™‚
