1996 Winnebago Relay
bowalker
I am having a hard time finding how to start a new topic.
I'll see if this works.
October 15, 2020 while traveling US 129 (I think) suddenly smoke boiled out from my 1996 Winnebago Adventurer P30 chassis (Chevrolet) dash. I pulled to the side of the road quickly and raised the dash (instrument panel) to see heavy smoke coming from the relays and wiring. Then it happened. An explosion, luckily I had closed the dash.
After an hour, I was on the road again.
Looking into the wiring from the top underneath the dash there are 2 relays and a bigger flat plug. The left relay burned to ash and burned a hole in the right one.
Can someone please get me a number for the relay on the left since mine is burned up?
Thank you for the help.
16 REPLIES 16
jhilley
Chances are the relay is the same as the one next to it.
2003 Winnebago Adventurer 38G F53 Chassis Solar Power
1999 Winnebago Brave 35C F53 Chassis Solar power
Handicap Equipped with Lift & Hospital Bed
1999 Jeep Cherokee Sport
1991 Jeep Wrangler Renegade
enblethen
That rules out those relays.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
bowalker
My MH does not have a slideout.
enblethen
On the Winnebago drawing 118003 Detail T shows two relays that power the slide outs. Does your slides work?
Relay part number is Winnebago part 63912-00-000
My rig does not have any relays as yours. mine is little older and does not have slides.
Bud
USAF Retired
Pace Arrow
enblethen
I will see what I can find in my rig. Sounds like the two larger reds are power and the two smaller are control.
Bud
USAF Retired
Pace Arrow
bowalker
Red Red smaller red and green
enblethen
Sorry, I was thinking P-30 and said Ford. Drawing I sent was for P-30.
What color were the wires going to the relay?
Bud
USAF Retired
Pace Arrow
bowalker
enblethen, My rig is a P30 Chevrolet. The relay is square and looks like the one on the site you posted. There is no possible way my relay could be working. It is ash. The coil which was inside is even melted.
I feel pretty blessed I got the fire extinguished. I cut the 4 wires from the relay end and capped them. I had to tape up several wires which had the insulation melted from them. I had to remove the melted plastic conduit before I could work on the wires. The AC duct is burned for maybe 14".
enblethen
Wiring diagram
Wiring diagram
I did not find much for relays. Is the item round or square/ Could it be a flasher?
Bud
USAF Retired
Pace Arrow
enblethen
The Winnebago drawings are for what they installed and not what came from Ford.
Bud
USAF Retired
Pace Arrow
bowalker
1995 Brave, I went to the website. But I can't determine a relay.
Thanks for the try.
enblethen
K Charles was making reference to the date, October 15, 2020.
The step should have two power sources. One motor power and one control, both normally fed from the 12 volt battery control center. Some rigs have a switch on the dash or by the door to override the operation.
The same relay is used for other functions, but is the same configuration. I would go through all aspects of your chassis operation. It is possible even though it is melted it could still be working.
Bud
USAF Retired
Pace Arrow
bowalker
enblethen, yes it does. However my instruments work. The only thing I have noticed not working are the steps. They extended and haven't moved any more.
K Charles,I have no idea what you mean.
1995brave
Go to the Winnebago website and look up your RV. Here is the link to the wiring,
Winni wiring
